In 2005, I built a system (my very first PC build) with Abit Fatal1ty An8 motherboard and a single core AMD Athlon 64 3500+.
Recent, I finally got the idea to replace the CPU with a much better one that is supported by the motherboard.  For only $12, why not?
So, I now have dual-core AMD Athlon X2 4200+ in my Abit Fatal1ty AN8 mobo.
I don't know if I have the latest version of the BIOS.
The POST screen recognizes that I have replaced the CPU.
Linux boots up just fine, but the processor info is not named in the BIOS or in Linux Mint 18.2
Linux only says what FAMILY the new CPU belongs to, but not really more than that.
I have not found any solution that truly relates my situation online, not even on YouTube.
PLEASE HELP!!
Maybe LinusTech would like to create a video about this - replacing/upgrading a CPU.
This is an old PC.  I wanted to upgrade what I could for a minimum cost.  I plan to give this PC away to someone I know in the near future.
After realizing this PC isn't as fast as I thought that it was, I have decided to build a whole new system.  Using a modest but flexible budget, here are the specs for my new build (FYI):
MSI B350M Gaming Pro motherboard ($65)
AMD Ryzen 5 1500X quad-core CPU ($150)
G.Skill TridentZ RGB DDR4 3200MHz 16GB (2x 8GB) ($175)
EVGA (modular) 450(W) B3 ($50)
Phanteks Enthoo Evolv Black mATX case ($120)
A-Data XPG M.2-2280 Gen3 x4 NVMe 128GB SSD ($75)
Total = $635 (with Black Friday special prices)
This will be my 2nd PC build.
Why upgrade an old system if I'm building a whole new one??  Because I want my old CREATION to live on as long as possible, no matter who uses it.
Thank you,
Ben J.
https://linustechtips.com/topic/864021-motherboard-not-recognizing-cpu/
Is there a graphics card in the new system? Because I don't think Ryzen has an iGPU
If you ever want to overclock Ryzen, now or in the future. That MSI motherboard is not great for overclocking, I'm not sure if it has been fixed but its BOIS didn't save frequency's you set it to. Also, it doesn't have a heatsink on the VRM's which also isn't great for overclocking. I would recommend this Board https://www.asrock.com/mb/AMD/AB350M Pro4/index.asp
has a heatsink on the VRM's and has a reputation of getting Ryzen to 4ghz
Are you sure it doesn't have a heatsink on the VRM's?
PLEASE HELP!!
Thank you,
Ben J.
You should probably grab the old CPU and make the sure the bios is the newest version. I'm fairly certain ABIT still has bios downloads on their website.
My main desktop, "Rufus":
PC Specs:
CPU: AMD Ryzen 5 1600
CPU Cooler: Cooler Master MasterLiquid Lite 120
RAM: 2x8gb Corsair Vengence DDR4 Red LED @ 3066mt/s
Motherboard: MSI B350 Gaming Pro Carbon
GPU: XFX RX 580 GTR XXX White
Storage: Mushkin ECO3 256GB SATA3 SSD + Some hitachi thing
PSU: Seasonic Focus Plus Gold 650W
Case: Corsair Crystal 460X
OS: Windows 10 x64 Pro Version 1607
Retro machine:
PC Specs:
CPU: Intel Core 2 Quad Q9550
CPU Cooler: Stock heatsink
RAM: GSkill 4gb DDR2 1066mt/s
Motherboard: Asus P5n-e SLI
GPU: 8800 GTS 640mb, I swap between that and my 8800 GTS 512mb
Storage: Seagate 320gb right from 2006
PSU: Ultra 600W
Case: Deepcool Tesseract SW
OS: Windows XP SP3 32-bit, Linux Mint 18.2 Cinnamon 64-bit, Manjaro Deepin x64 (sorta)
Mac Pro Early 2008: Dual Xeon X5482s w/ 32GB RAM & HD 5770 running macOS High Sierra
More PC's
I assume that I don't need a GPU because the MoBo has 3 different display connects - VGA for the screen I currently have and HDMI for a TV or whatever.  It doesn't make sense to have it if it can't be used.  Right??
Well, maybe I'm wrong.  I just discovered:
Bult_ar_org.gifOnboard Graphics
• 1 x VGA port, supports a maximum resolution of 2048x1280@60Hz, 1920x1200@60Hz*
• 1 x DVI-D port, supports a maximum resolution of 1920x1200@60Hz*
• 1 x HDMI™ port, supports a maximum resolution of 4096x2160@24Hz*
* Only support when using a 7th Gen A-series/ Athlon™ processor.
* Maximum shared memory of 2048 MB
I plan to wait until summer or next Christmas to add a GPU since I'm not a gamer, or I'll get one very soon if needed.  I may not try to overclock it until then.  After a year, I may also switch the stock AMD cooler with a quality water cooler.  A new monitor will also come later.
I looked at the Asrock board.  It isn't the color I desire.  I wanted a BLACK motherboard for this build.  And, I didn't see anything else that interested me either.  The MSI B350M offers more of what I desire.  I plan to black out everything that isn't RGB or the red LED that comes from the motherboard.
Can you please explain what you mean by "3-phase design"??  I googled it and didn't find any info about it.
I don't know what VRM stands for.  Virtual Ram Memory??
I briefly explored to see what GPUs were out there and for what price.  For less than $200, there were 2 that I think might be a good choice:
Gigabyte Geforce GTX 750Ti 4Gb GDDR5
         or
MSI Geforce GTX 1050 Ti 4Gb GDDR5
Why not get the R5 1600 instead? Just a couple of Starbucks more.
CPU/ CPU Cooler: i7-6700K - 4.5GHz with Noctua DH-15S | Motherboard: ASUS Z170 Pro Gaming | RAM: 2x8GB Corsair Vengeance LPX DDR4 2400MHz | SSD: Samsung 850 EVO 250GB M.2 | HDD: Western Digital Caviar Blue 1TB 7200 RPM | GPU: Zotac GeForce GTX 1060 Amp! Edition | Case: Corsair 400C | PSU: FSP Aurum S 650W | OS: Windows 10 Pro 64-Bit
Monitor: BenQ GL2460HM FHD | Speakers: JBL Pebbles | Keyboard: Logitech G710+ | Mouse: Steelseries Sensei 310
