LAN TO WAN - ISSUE
23 minutes ago, MaxiMax07 said:I'm using router 2 to isolate the neighboor. He'll use this one. I disabled the NAT on it so only the router 1 who provides the internet directly from the modem will have the NAT enabled.
It's just so we don't cross our chromecasts.
Have you connected router 2 to router 1 using the WAN port? If so, it won't work without NAT and if you use NAT, it's likely to struggle because it's expecting a WAN connection but is getting a local connection using double NAT. You'd need to set the WAN settings on router 2 to use router 1 as its default gateway if it will let you. I'd have both set to use Google's Public DNS.
This is how I'd have it set up personally. From my experience with double NAT and to some extent, just multiple routers in general, they're a pain to work with. While it would need new hardware, it's the better solution to me. It splits the network into two so they can't interact with each other. You could set a computer as a DHCP server on each if you wanted, but I would really just use the router for DHCP, for the most part it doesn't matter if they use the same IP address range as they still can't interact.
