Which fan header is better?
7 minutes ago, Cuboid88 said:
its corsair af140m
The Corsair SF140 doesn't seem to have a PWM (4 pin) plug. I'd say plug it into the fan controller for easier use.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
its corsair af140m
I'm pretty sure that comes in both configs. Does it have 3pin or 4pin connector. Also which mobo?
And about that controller. If you have using med setting, it only uses 7V on fans. Crank it to high for full power.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
my motherboard is prime x370 pro and its at full settings im not concerned about changing speeds i just want it to run at max capacity
That mobo has really good fan controls if you want to use them. If fan hub is already set to highest setting, then thats fastest those fans will spin.
What do you mean by the fans feeling weak?
