Search In
  • More options...
Find results that contain...
Find results in...
Cpu cooler for i7-6850k
Ես վատ
 Share
Go to solution Solved by WoodenMarker,
11 hours ago, Ես վատ said:
sorry about that pretty new to actually making posts.
ram:Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory
Budget/location: around $100 for the cooler ($US)
case:Inwin - 703 BLACK ATX Mid Tower Case
current cooler:CRYORIG M9i Mini Tower Cooler
Depending on how much you'd prefer to spend, some good options include
Kotetsu: https://pcpartpicker.com/product/7998TW/scythe-cpu-cooler-scktt1000
Mugen 5 Rev. B: https://pcpartpicker.com/product/8GBrxr/scythe-mugen-5-rev-b-512-cfm-cpu-cooler-scmg-5100
NH-D15: https://pcpartpicker.com/product/4vzv6h/noctua-cpu-cooler-nhd15
So in the next couple of months im going to get a i7-6850k for my pc but the problem is that my cpu cooler isn't compatible for it and I need a good recommendation for a cooler (I will be overclocking)
5
Depends on how much you want to overclock and what your budget is. What is your budget?
Any particular reason for the 6850K over the 8700K or R7 1700?
Sincerely,
me
I use this Corsair one and my 6850K is overclocked to 4.4Ghz
What cooler are you currently using?
Where are you shopping/located? Budget? What ram and case are you using?
The air cooler can't be above 100
it's kinda over budget but by the time I have the money for the cpu I might be able to get a 8700k
yeah the radiator won't be able to fit my case
 Share
