I have never built a pc before but I feel I have done enough research for this pc to be very nice. I plan to play 1080p now but plan to move up to 1440p monitor in the future. Please tell be any advice for first time builders and feel free to make suggestions on different components and I would like to spend no more then 1200 https://pcpartpicker.com/list/Jtxqcc
https://linustechtips.com/topic/861378-help-me-pick-my-components/
What parts do you have?
You've left out a mouse so I'm assuming you have one, but if you have any other peripherals, it might be an okay choice to re-use.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://pcpartpicker.com/list/sfGFzM
Peep this out it's only $70 over but it's much much better. :)
Former Bronze Contributor
CPU: Intel i7-7700K 4.2 GHz / CPU Cooler: Cryorig H7  / Board: ASRock Z270 Taichi / GPU: Nvidia 1060 6gb EVGA SC / GPU Cooler: NZXT Kraken G12 with Thermaltake Water 3.0 120mm RAM: White Corsair Vengeance LPX 16GB DDR4 2666 MHz SSD: 2x Samsung 850 Evo 250 and 3TB WD blue HDD / PSU: Corasir 550cx / Case: NZXT s340 Elite White
Im a super Italian. Kapish.
2 minutes ago, TheCatShuriken said:
I second that, an MSI Mortar or Gaming Pro might do the trick.
*facepalm*
B350M is awful, Mortar is better but still meh.
You want atleast Prime B350 Plus for R5 1600
Don't buy Apple M1 computers with 8GB of RAM
10 minutes ago, dave_k said:
The mobo is piece of junk
the mobo isn't that bad, mines been running my 1600 at 3.8ghz just fine since they were purchased in May.
Edit - just realised his list has the gaming 3 where mines the plain "gaming" with no numbers. can't imagine they're too different though.
17 minutes ago, TheCatShuriken said:
I'm personally using a Mortar and I havent had a single hitch, but to each their own I guess.
Does it have Niko fets yes => don't even consider it
                                        yes but a lot of them=> you might wanna consider it i'd but generally avoid it
                                        no => consider it
47 minutes ago, dave_k said:
*facepalm*
29 minutes ago, dave_k said:
trash
                                        no => consider it
Explaining why initially would be better.
USEFUL LINKS:
PSU Tier List F@H stats
I explained it in the last comment, simply to not confuse potentional newbie looking into that.
Also, where do i put the links to the pictures with lists if not in my signature?
