Hi all. I made a post a couple days ago mentioning about my CPU idleing at 90-100c.
I was told to start with the heat sink and reapply thermal paste. So i went out an purchased a h100i v2 and some new thermal paste.
im still experiencing the high temps.
Air flow in the case is effecient. 3 intake fans in the front, 3 exhaust on the top and one exhaust on the back. Could it be possible the CPU or motherboard could have failed and need replaced? System specs are below if it helps...
CPU: Inte core i5 3470 @ 3.4Ghz
PSU: Corsair RM850
GPU: Evga GeForce gtx 970 SC
Mobo: Intel Gaming Motherboard(Don't remember exact model number)
https://linustechtips.com/topic/861087-cpu-temp-running-high/
Could be a faulty mobo as I've read in some cases where they have a messed up temp sensor. Could be the CPU ... Either way it could be the temp sensor. When you stress the system does it auto shut off?
[CPU] - Intel Core i5-4590
[Motherboard] - MSI B85-G43 GAMING
[RAM] - Kingston HyperX Beast (2x4GB) 1866Mhz... CPU only supports 1600Mhz
[SSD] - A-Data SP600 128GB SSD
[HDD]- 1Tb Seagate Barracuda
[GPU] - EVGA GTX 1060 6GB SSC
[Case] - Corsair SPEC-03 White
[PSU] - Rosewill 450W 80+Bronze
https://linustechtips.com/topic/861087-cpu-temp-running-high/#findComment-10711891
I notice the performance decrease in games. But the Pc Never shuts off.
https://linustechtips.com/topic/861087-cpu-temp-running-high/#findComment-10711924
18 minutes ago, White Lightning said:
I ran intel burn test and the temps go to 110c and it hasn't shut off on me.
Then that's a faulty temp sensor. Just to check whether all of them are going wrong, can you check all sensors with HWinfo?
Desktop benching:
https://linustechtips.com/topic/861087-cpu-temp-running-high/#findComment-10711963
Yes i can. I can verify all are running at the same high temps. Or off by a 1 or 2 degrees.
https://linustechtips.com/topic/861087-cpu-temp-running-high/#findComment-10711974
