Possible dead CPU?
Go to solution Solved by Anghammarad,
Sounds like the CPU got a hit as well...
ok another option yould be both used PSU are broken... but I won't go that far.
Was replacing a broken mobo with a new one, but now it is having issues powering on.
Cpu was recently working with the old motherboard. However now that mobo is having the same issues with this new one.
Old mobo: MSI X99A SLI PLUS
New mobo (it was DOA): EVGA X99 FTW K
Newer mobo (Received it today): ASRock X99 Taichi
i7 5820k
GTX 980
2 x 8gb G. Skill Trident Z (2133)
WD Blue m.2 SATA SSD
EVGA 750G NEX
EVGA 850BQ (Extra PSU)
Have tried:
-Clear cmos
-Reseat cpu
-Tried different ram slots with one stick
-Tried different PSU
-Switched to bios 2
It does not power on long enough for the debug codes to come on, (Will power on for a split second then turns off)
https://linustechtips.com/topic/861063-possible-dead-cpu/
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
https://linustechtips.com/topic/861063-possible-dead-cpu/#findComment-10711668
i bought the 850 watt psu for testing about a week ago. it is new.
Would there be any other way of making sure it is the cpu?
https://linustechtips.com/topic/861063-possible-dead-cpu/#findComment-10711673
put in another working cpu into the mobo...
Main System:
https://linustechtips.com/topic/861063-possible-dead-cpu/#findComment-10711681
well aside from that. issue being i do not have another x99 cpu on hand, the only available in-store ones cost $1,000. It would be preferred to not spend more until definitely confirmed.
https://linustechtips.com/topic/861063-possible-dead-cpu/#findComment-10711697
you could spend the same to "burn through" more motherboards that give the same issues.
Ok the devil is in the details and I saw administrators emptying their stomach in front of the server room doors, so the "luck" that both mobos are broken and your cpu isn't is given, but to be honest, really small.
Main System:
https://linustechtips.com/topic/861063-possible-dead-cpu/#findComment-10711708
10 minutes ago, Tigersoze said:
Then i'll have to come to the conclusion of the cpu died.
If you have a computer store in your vincity like the ones I have, you could bring your machine there and ask them to test it for you, this would clear things up, the shop here takes 50 bucks for a quick look/testing.
Main System:
https://linustechtips.com/topic/861063-possible-dead-cpu/#findComment-10711740
Best Buy is the only one near. Do they offer that?
https://linustechtips.com/topic/861063-possible-dead-cpu/#findComment-10711745
That I can't tell... I have pure computer stores around. Their website should tell you if they are offering this kind of support... But I personally would doubt it.
Main System:
https://linustechtips.com/topic/861063-possible-dead-cpu/#findComment-10711756
