Safe Temps for Laptop
Go to solution Solved by SpeedyBoJangles,
Ok so I used AMD's official utility (AMD Overdrive) and it reports temps 60-65 degrees so I think I will have to believe the official utility for my CPU
Hi everyone,
I recently bought a new ultra-thin notebook for school and some light Call of Duty and Battlefield when I am at school away from my desktop. It has an AMD A-10 5757M and a Radeon 8750M I was playing Battlefield 4 on it the other day and when finished checked HW Monitor and my CPU temp was 134 C (273 F) I was wondering if this should be something to worry about as it idles at 110 C when in in high performance mode (3.5 GHz) and around 90 C when in power save mode (1.4 GHz) The bottom of the laptop gets way to hot to touch without hurting myself when gaming. Are these temps ok or should I return it to Amazon?
I would like to add that performance doesn't degrade even know its running so hot, I am able to keep a rock solid 60 FPS in Battlefield at low settings (ultra textures) at 720p
https://linustechtips.com/topic/86047-safe-temps-for-laptop/
Those are dangerous levels of heat. Check to make sure the fans are spinning, and the intake isnt obstructed (i.e. no dust or something blocking). Otherwise, yeah probably send it back.
^Also, yeah like Shady said, it should have auto shut off at those temps.
CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ
https://linustechtips.com/topic/86047-safe-temps-for-laptop/#findComment-1168900
Ya the fan spins up, the thing sounds like an old XBOX 360, it hasn't shut itself down yet. Ive checked around online and apparently the max safe temps for this CPU is 100 C. its brand new so there is no dust buildup and I was playing on a wooden desk. Im going to try a few other applications to montor temps to see if HW Monitor is reporting temps incorrectly (probably not though) it says the integrated GPU (8650G) is at 54 C though which does not make sense to me if they are on the same chip.
https://linustechtips.com/topic/86047-safe-temps-for-laptop/#findComment-1168937
Hmmm. Speccy is reporting the same as HW Monitor... not sure which to believe, after all HW Monitor did say my FX 8350 was at -14 C once  :huh:
How about trying RealTempGT?
Setup: i5 4670k @ 4.2 Ghz, Corsair H100i Cooler, Corsair Vengeance Pro 16GB Ram @ 1600 Mhz, MSI Z87-GD65 Motherboard, Corsair GS700 2013 edition PSU, MSI GTX 770 Lightning, Samsung EVO 120 SSD + 2TB&1TB Seagate Barracudas, BenQ XL2411T Monitor, Sennheiser HD 598 Headphones + AntLion ModMic 4.0
https://linustechtips.com/topic/86047-safe-temps-for-laptop/#findComment-1169085
