No just looks and flexibility.
https://linustechtips.com/topic/860184-tubing-question/#findComment-10702466
22 minutes ago, DuckGender said:
Does the size/thickness of the tubing effect temperatures?
Not in anyway that is noticeable really, say between 3/8"ID us 1/2"ID, if yo start going really small like 1/4"ID that can have a few degrees of difference but that size is also not common in custom watercooling.
Thick walled tubing would be a good choice however since it can have tighter radius bends without kinking.
https://linustechtips.com/topic/860184-tubing-question/#findComment-10702562
