Hey guys,
So I got this laptop a while ago and it has had the 100% disk load error since purchase (approx 9 months). I have tried everything thing I can find online to fix it with no success. I'm not sure what else to do but it is has been really bugging me lately as it is a fairly good laptop but feels like a junkyard laptop.
Any help is appreciated, thanks guys.
https://linustechtips.com/topic/860003-100-disk-usage-help-me/
disk space used? just delete some crap you don't need. problem solved.
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/860003-100-disk-usage-help-me/#findComment-10700352
If it has been happening for 9 months, presumably you have run a hard disk check and looked at everything here https://www.drivereasy.com/knowledge/fix-100-disk-usage-in-task-manager-improve-pc-performance-on-windows-10/
Probably gaming or helping technophobes with tech...
https://linustechtips.com/topic/860003-100-disk-usage-help-me/#findComment-10700354
That is disk load, it has nothing to do with available space.
13 minutes ago, Polki said:
Hey guys,
So I got this laptop a while ago and it has had the 100% disk space error since purchase (approx 9 months). I have tried everything thing I can find online to fix it with no success. I'm not sure what else to do but it is has been really bugging me lately as it is a fairly good laptop but feels like a junkyard laptop.
What is the exact model of your laptop? Can you post a screenshot of your "my computer" folder?
Does this error prevent you from doing anything, or is it just annoying?
sudo chmod -R 000 /*
https://linustechtips.com/topic/860003-100-disk-usage-help-me/#findComment-10700370
If you mean it's showing 100% disk usage in task manager all the time, it's probably designed to. Most laptop manufacturers put really slow HDDs into their laptops, you can fix it by replacing the drive with an SSD.
I edit my posts a lot.
https://linustechtips.com/topic/860003-100-disk-usage-help-me/#findComment-10700382
Oh my bad I read it wrong. Not seen this before.. I would have taken it back straight away instead of 9 months later. Just call the manufacturer and check the warranty is still valid and have it fixed/replaced.
https://linustechtips.com/topic/860003-100-disk-usage-help-me/#findComment-10700421
Going to try this today, cheers.
https://linustechtips.com/topic/860003-100-disk-usage-help-me/#findComment-10702304
Don't understand why it would be designed to as it does it from idle and finds it super hard to open any programs in more than 5 minutes. This includes file explorer etc
https://linustechtips.com/topic/860003-100-disk-usage-help-me/#findComment-10702309
my apology I did, in fact, mean disk load. Attached is my specs and a screenshot of, my computer and task manager.
https://linustechtips.com/topic/860003-100-disk-usage-help-me/#findComment-10702388
yeah I have tried all of those techniques with no luck
https://linustechtips.com/topic/860003-100-disk-usage-help-me/#findComment-10702394
I thought you meant that! it's a really common issue! You often find when you look in your resource monitor (in task manager) that the disk load culprit is actually windows system files. It's caused by corruption to system files so firstly run a checkdisk repair (open a cmd prompt and type "chkdsk /f c:" without the quotations) it will then want to do a restart to commence scanning and will repair anything it finds hopefully. When Windows boots up again after go back into cmd and type "sfc /scannow" to scan your OS and repair any files. If it still does it then you can try a reinstall.
https://linustechtips.com/topic/860003-100-disk-usage-help-me/#findComment-10704351
Not always.. Sometimes it's because you lack the sufficent RAM. When I play specific games that require alot of loading, the disk usage goes to 100% because I'm out of memory. Not sure tho, it's either HDD or RAM imo.
https://linustechtips.com/topic/860003-100-disk-usage-help-me/#findComment-10705238
Boyfriend's desktop has been doing the same for a while. Definitely seems like Windows processes hammering on boot. Causes the whole system to chug along and no amount of online remedies have yeilded results.
His laptop starts the same but settles down after a minute or two. He doesn't even bother using the desktop anymore as it never seems to settle down anymore. Just stays at 100%.
https://linustechtips.com/topic/860003-100-disk-usage-help-me/#findComment-10706217
