Floatplane Downloader & Plex [With Code & Guide]
Go to solution Solved by Inrix,
Version 5.13.0 - SPEED, Fixes & Metrics (GitHub)
4.0.3 Has received a shadow update fixing those issues. Everything should be working fine now
~ Main Rig ~
- Ryzen 9 3950X 16 Core 32 Threads - EVGA 3090 KINGPIN HYBRID - 32GB DDR4 3600mhz -
- 6TB SSD Array + 2TB MP600 NVME Gen4 Boot -
- Gigabyte X570 AORUS MASTER - Lian li O11 Dynamic XL - NZXT Kraken X73 + 16 Noctua NF-A12x25 Fans -
~ Accessories ~
- Logitech G915 + G903 - LG C9 OLED PG279Q 27'' [1440p 165hz G-Sync] +  PG27AQ27'' [4k 60hz G-Sync] -
2x 1440p Portrait 25'' Dell - DT 990 Pro Headphones -
~ Servers ~
- 100TB NAS + Server's w/ 6700k - 32 + 64GB Ram - NVME Boot - Gigabit Unlimited Fiber -
  • 2 weeks later...
12 hours ago, davmc said:
Been trying to setup the latest version of the script, but I keep getting this error when I try and run it from the .bat file. Anyone got ideas on how to sort this?
That is a issue with login. Looks like the script isnt correctly handling the error. Anyway make sure that you are using the correct credentials (Floatplane.com not Linustechtips.com) when trying to use the script. I have just pushed out a silent update to 4.0.3 that will properly handle that error again so I also suggest downloading that version again. If you need any more help a faster way to contact me is on discord, otherwise here is fine :)
~ Main Rig ~
~ Accessories ~
~ Servers ~
I think its an account details problem. My floatplane account is created from my forum account and I can't seem to login with my forum credentials or create different credentials for it on the Floatplane.com site since they are linked. I think I probably need to to wait until my current subscription expires or something and make a new account.
You can't use form credentials with the new version of the script. What you need to do is make a new floatplane.com account and then link your form account to it in the account settings page. I might make a guide that better explains this since a few people haven't quite got it the first time.
~ Main Rig ~
~ Accessories ~
~ Servers ~
That's exactly what I had to do, worked perfectly :)
28 minutes ago, Malixk said:
but that mean i need a new mail too
No, just go to this page and sign up with your current email, I even used the same username and password as the forum so I wouldn't forget
https://www.floatplane.com/signup
Once logged in I think you have to go to this page to link to your forum account
https://www.floatplane.com/user/connections
Pretty sure that the api just updated and broke logins. I will look into it later but if you already have credentials saved you should be fine. Otherwise just use manual cookies mentioned in the guide on github for now if you have to reauthenticate.
~ Main Rig ~
~ Accessories ~
~ Servers ~
Sorry for the recent radio silence, been pretty busy with stuff. A few bugs and feature requests have come up so I'll try work on them this weekend as I'll have time :)
~ Main Rig ~
~ Accessories ~
~ Servers ~
Seems like Floatplane.com has changed how login works again, and have disabled logging in via the api. For now you will need to use the manual cookies method and periodically load floatplane.com in a browser to use the script. Im looking into a fix.
~ Main Rig ~
~ Accessories ~
~ Servers ~
Mines still working, is this only new installs?
If it has the cookies its fine because floatplane.com persists cookies so you don't get signed out unless you sign out specifically. So you can still use the script if you manually get cookies. It's just the script can't grab them itself since the floatplane api straight up returns 404 for login, even though none of the references have changed for logging in within their js files. So I'm kinda lost as to what's happened.
~ Main Rig ~
~ Accessories ~
~ Servers ~
Version 4.0.4 - Floatplane Login Fixes (GitHub)
Release 4.0.4.zip
Install.zip
Update.zip
This is just fixes for floatplane.com login being changed, that is now working again. I'm working on a massive update so currently this isnt very feature rich. I was intending to add logging for @rob1998 in this release but I have decided to hold it for the big update as I cannot do it properly in this one.
Changelog
v4.0.4
  • Fixed login not working due to floatplane.com changes
  • Fixed login checks to work with new login functionality
Install Guide
If your updating then just download the Update.zip extract it to your install folder and run it. It will automagically update all the needed files and move your settings over.I suggest double checking that everything is correctly updated in the settings.json though it should move your old settings over properly.
For people who are doing a fresh install just follow the below guides:
As always if you run into any issues you are free to Create a issue here, Contact me on Discord @sirInrix | <3#6950 or Leave a comment on the LTT form post
~ Main Rig ~
~ Accessories ~
~ Servers ~
We now have a discord server for people who want to chat, suggest idea's or get help installing, updating, side-dating and more! Go head there now if you wanna chat or get help etc.
https://discord.gg/aNTyMME
~ Main Rig ~
~ Accessories ~
~ Servers ~
Version 4.0.5 - API Update Fixes (GitHub)
Release 4.0.5.zip
Install.zip
Update.zip
This is just fixes for floatplane.com API being changed. Currently I am putting the majority of my work into the 5.0 update so this branch will just be getting fixes for now.
Hopefully v5 Will be coming soon!
Changelog
v4.0.5
  • Fixed issue with script not handling site returning no videos
  • Fixed issue with script not fetching subscriptions due to api update
Install Guide
As always if you run into any issues or want to chat you are free to
Create a issue on GitHub here
Join the Discord Server! https://discord.gg/aNTyMME
~ Main Rig ~
~ Accessories ~
~ Servers ~
Version 4.2.6 - API Fixes - New Features & Video Detection Rewrite (GitHub)
Release 4.2.6.zip
Install.zip
Update.zip
This is a big release with a bunch of new features! As always you can read about settings on the wiki here: Settings Info
The big change for this release is that video information is now stored within a videos.json file, this is to avoid duplicate videos being downloaded when their titles have invalid regex characters. This update will mean that you need to redownload any videos that you had downloaded before this, however you really only need to download the last x number of latest videos you have the script to look for.
This release had added Logging to a file, auto fetching the download server and the ability to disable ffmpeg.
There are also a bunch of fixes that you can read through below.
I changed a lot in this so if you run into any issues please contact me on Discord, Github or the LMG form.
If you aren't on the discord you should Come Join! Any hotfixes for bugs are posted there well in advance before hitting my GitHub or the Form.
Changelog
v4.2.6
  • Added setting logging
  • Added setting logFile
  • Added logging to a file
  • Added setting ffmpeg
  • Added the ability to disable ffmpeg processing
  • Added setting autoFetchServer
  • Added the ability to automatically fetch download server for your region
v4.1.6
  • Fixed issue with script failing on videos with no thumbnail
  • Added videos.json to store downloaded videos
  • Rewrote video detection code to use guid
  • Fixed subchannel Ignore not working
  • Fixed some files being mistaken for channels when doing a episode count
  • Better error handling & auto restart on partial failure
Install Guide
~ Main Rig ~
~ Accessories ~
~ Servers ~
  • 1 month later...
Version 4.2.8 - Fixes (GitHub)
Release 4.2.8.zip
Install.zip
Update.zip
This is a smaller release with a few fixes mainly related to Issue #12 along with a few other small issues that were discussed on the Discord
This also includes some 4.2.7 fixes that never got pushed further than the discord.
Changelog
v4.2.8
  • Prouser123 Helped with fixes & spelling
  • Fixed issue with fetching subscriptions
  • Removed setting checkForNewSubscriptions
  • Fixed issue with Edge01 floatplane servers no longer working but still being the default the api returns
  • Fixed issue with non LTT subscriptions not properly working due to a missing ignore setting
v4.2.7
  • Changed videos.json and partial.json to have some locking for writing out files to avoid corruption
  • Fixed logging setting not working
Install Guide
If you're updating then just download the Update.zip extract it to your install folder and run it. It will automagically update all the needed files and move your settings over.I suggest double checking that everything is correctly updated in the settings.json though it should move your old settings over properly.
~ Main Rig ~
~ Accessories ~
~ Servers ~
  • 4 months later...
13 hours ago, Magto said:
This question might have been asked, but I couldn't find anything the the git-hub page. is there a way to include WAN-show as a download? I would love to be able to skip going to YT to watch WAN-show...
As WAN show isn't uploaded to floatplane it is not downloaded. The only way to get it would be to use a YouTube or twitch downloader... I dunno if there is a thing that exists for automatically downloading wan but it's something that I could probably work on in the future if there is Intrest.
~ Main Rig ~
~ Accessories ~
~ Servers ~
  • 4 weeks later...
Version 4.4.0 - 2 Factor Support & Fixes (GitHub)
Release 4.4.0.zip
Install.zip
Update.zip
This is a big update with the main addition being 2Factor support for login. It also has a variety of fixes and some new QOL settings.
Changelog
v4.4.0
  • Added support for 2Factor Authentication
  • Updated default floatplane API url to new formatting
  • Fixed setting logging so it actually disables logging
  • Changed login code to better deal with repeated incorrect details
  • Fixed script restarts so on recovered errors its automatic
  • Updated all dependencies to remove security vulnerabilities
  • Added debug function for internal use
  • Removed old fixes forcing the use of the Edge02 API
  • Fixed subscription storage and parsing to avoid duplicates and other issues
  • Removed old code
  • Fixed spacing code to work properly for small numbers of videos
  • Updated partial.json to be properly spaced
v4.3.0
  • Keep existing subscription perferances when doing subscription checks | Thanks @peskdale
  • Added setting artworkFormat > Allows setting the file type used for thumbnails | Thanks @peskdale
  • Added setting formatWithSubChannel > Allows removing the subChannel eg, "TechLinked" from title | Thanks @peskdale
  • Fixed issues with Floatplane API Url changing for downloading videos | Thanks @peskdale
  • Fixed TechLinked detection code using outdated references | Thanks @peskdale
Install Guide
~ Main Rig ~
~ Accessories ~
~ Servers ~
  • 3 weeks later...
On 1/12/2019 at 10:28 PM, Magto said:
That would be fantastic!
The latest beta has WAN show support, you can grab it off the discord. Should be released in the next few days.
~ Main Rig ~
~ Accessories ~
~ Servers ~
  • 2 weeks later...
Version 4.5.0 - WAN Show, Fixes & Tweaks (GitHub)
Release 4.5.0.zip
Install.zip
Update.zip
This update cleans up a lot of old code and add's support for downloading the WAN show off youtube as a plex series. There are also a bunch of fixes for edge determination, techquickie matching and other things.
Changelog
v4.5.0
  • Variety of other rewrites/changes and fixes
  • Added setting TheWANShow
  • Added youtube download support for The WAN Show
  • Rewrote download functions to consolidate code
  • Changed Techquickie to determine subChannel by title identifier rather than description
  • Rewrote most text concat to use new method
  • Removed outdated/leftover code from older versions
  • Added new function for determining best edge server to use
  • Removed unnecessary settings save
  • Added check to ensure script does not repeat if its still downloading
Install Guide
~ Main Rig ~
~ Accessories ~
~ Servers ~
