Floatplane Downloader & Plex [With Code & Guide]
Go to solution Solved by Inrix,
Version 5.13.0 - SPEED, Fixes & Metrics (GitHub)
3 minutes ago, jt999 said:
Awesome, I've had to disable it for now as it's repeatedly trying to download the CES coverage and failing. For now I can live manually downloading though :)
Its technically updated now if you want to pull the files directly and run npm update. But I decided I wanted to work on a nicer way for the script to update so its been delayed for a bit. Will definitively be out today though.
~ Main Rig ~
- Ryzen 9 3950X 16 Core 32 Threads - EVGA 3090 KINGPIN HYBRID - 32GB DDR4 3600mhz -
- 6TB SSD Array + 2TB MP600 NVME Gen4 Boot -
- Gigabyte X570 AORUS MASTER - Lian li O11 Dynamic XL - NZXT Kraken X73 + 16 Noctua NF-A12x25 Fans -
~ Accessories ~
- Logitech G915 + G903 - LG C9 OLED PG279Q 27'' [1440p 165hz G-Sync] +  PG27AQ27'' [4k 60hz G-Sync] -
2x 1440p Portrait 25'' Dell - DT 990 Pro Headphones -
~ Servers ~
- 100TB NAS + Server's w/ 6700k - 32 + 64GB Ram - NVME Boot - Gigabit Unlimited Fiber -
Version 3.4.0 (GitHub)
The 3.4.0 Release is out!
This release contains fixes from versions 3.0.1 to 3.0.3 and a bunch of new features from there to 3.4.0!
This release contains a large amount of updates and fixes all consolidated together!
Short Changelog
  • You can now easily Install and Update the script using the batch's inside Update.zip or Install.zip.
  • Support for Embedded YouTube Videos is posts & downloading multiple pages is now in.
  • A fix for CES2018 content added.
  • An option to force login every time the script runs to remove temp session issues.
  • There are a bunch of new settings which you can read about in the Settings Info wiki page.
  • More info in the full changelog below
Install Guide
If your updating then good news! Its super easy now, just download the Update.zip extract it to your install folder and run it. It will automagically update all the needed files and move your settings over.
I suggest double checking that everything is correctly updated in the settings.json though.
For people who are doing a fresh install just follow the below guides:
As always if you run into any issues you are free to Create a issue here, Contact me on Discord @sirInrix | <3#6950 or Leave a comment on the LTT form post.
Full Changelog
v3.4.0
  • Added install.bat & install.js for easy installs
  • Updated all documentation relating to this
  • Possibly something else I missed a bunch of rewrites to scripts
v3.3.0
  • Added update.bat & update.js for easy updating
v3.2.0
  • Added optional maxPages setting to allow downloading more than one page of videos
v3.1.0
  • Added subcategory for CES (LTT@CES)
  • Added handling for embedded youtube videos
  • Added optional forceLogin setting for session issues. This will force login every time the script runs removing the possibility of session errors.
  • Added support for youtube videos in a post
  • Fixed videos being ordered in reverse on first download
v3.0.3_dev
  • Fix for cookie not being cleared on invalid session
v3.0.2_dev
  • Proper fix for check invalid session key
  • Commented all new code from 3.0
v3.0.1_dev
Changelog
  • HotFix for invalid session key
3.4.0_manual,zip
Install.zip
Update.zip
~ Main Rig ~
~ Accessories ~
~ Servers ~
1 hour ago, jt999 said:
No rush dude, what you've done already is amazing!
*Starts working on a quicc update for CES issues at 2pm... 7 Hours Later... :P
The new update.bat and install.bat files are gonna be way nicer to use though!
~ Main Rig ~
~ Accessories ~
~ Servers ~
I get tons of errors with the update.zip
Running as normal user:
E:\Scripts\FloatPlaneDownloader>CMD /C npm install request prompt fs adm-zip --s
ave
npm ERR! path E:\Scripts\FloatPlaneDownloader\node_modules\.bin\uuid.cmd
npm ERR! code EPERM
npm ERR! errno -4048
npm ERR! syscall unlink
npm ERR! Error: EPERM: operation not permitted, unlink 'E:\Scripts\FloatPlaneDow
nloader\node_modules\.bin\uuid.cmd'
npm ERR!  { Error: EPERM: operation not permitted, unlink 'E:\Scripts\FloatPlane
Downloader\node_modules\.bin\uuid.cmd'
npm ERR!   cause:
neDownloader\node_modules\.bin\uuid.cmd'
npm ERR!      errno: -4048,
npm ERR!      code: 'EPERM',
npm ERR!      syscall: 'unlink',
npm ERR!      path: 'E:\\Scripts\\FloatPlaneDownloader\\node_modules\\.bin\\uuid
.cmd' },
npm ERR!   stack: 'Error: EPERM: operation not permitted, unlink \'E:\\Scripts\\
FloatPlaneDownloader\\node_modules\\.bin\\uuid.cmd\'',
npm ERR!   path: 'E:\\Scripts\\FloatPlaneDownloader\\node_modules\\.bin\\uuid.cm
d',
npm ERR!   parent: 'Floatplane-PlexDownloader' }
npm ERR!
npm ERR! Please try running this command again as root/Administrator.
npm ERR! A complete log of this run can be found in:
npm ERR!     C:\Users\Plex\AppData\Roaming\npm-cache\_logs\2018-01-10T09_09_50_5
05Z-debug.log
E:\Scripts\FloatPlaneDownloader>node update.js
module.js:538
    throw err;
Error: Cannot find module 'adm-zip'
    at Function.Module._resolveFilename (module.js:536:15)
    at Function.Module._load (module.js:466:25)
    at Module.require (module.js:579:17)
    at require (internal/module.js:11:18)
    at Object.<anonymous> (E:\Scripts\FloatPlaneDownloader\update.js:4:16)
    at Module._compile (module.js:635:30)
    at Object.Module._extensions..js (module.js:646:10)
    at Module.load (module.js:554:32)
    at tryModuleLoad (module.js:497:12)
    at Function.Module._load (module.js:489:3)
E:\Scripts\FloatPlaneDownloader>CMD /C npm update
E:\Scripts\FloatPlaneDownloader>pause
Press any key to continue . . .
Running as Administrator:
C:\Windows\system32>CMD /C npm install request prompt fs adm-zip --save
npm WARN saveError ENOENT: no such file or directory, open 'C:\Windows\system32\
package.json'
npm WARN enoent ENOENT: no such file or directory, open 'C:\Windows\system32\pac
kage.json'
npm WARN system32 No description
npm WARN system32 No repository field.
npm WARN system32 No README data
npm WARN system32 No license field.
+ adm-zip@0.4.7
+ prompt@1.0.0
+ fs@0.0.1-security
+ request@2.83.0
added 19 packages and updated 2 packages in 1.344s
C:\Windows\system32>node update.js
module.js:538
    throw err;
Error: Cannot find module 'C:\Windows\system32\update.js'
    at Function.Module.runMain (module.js:676:10)
    at startup (bootstrap_node.js:187:16)
    at bootstrap_node.js:608:3
C:\Windows\system32>CMD /C npm update
C:\Windows\system32>pause
I'll try manually updating :)
Update: Might be a few bugs... Sorting them now but shouldn't need another update *Hopefully* :) Hold tight and try update for now.
~ Main Rig ~
~ Accessories ~
~ Servers ~
8 minutes ago, jt999 said:
-Snip-
The update script should be working now. Can you try run it again? Also if it doesn't work can you try running it as a admin and as a non admin?
Hopefully it was just me accidentally uploading the wrong file...
~ Main Rig ~
~ Accessories ~
~ Servers ~
I just updated the Update.zip to fix a few things. Don't know if it will help with your errors @jt999 But until you can try with the new version/admin I cant fix it :)
~ Main Rig ~
~ Accessories ~
~ Servers ~
Same errors, I think it needs to run as admin, but it then uses C:\Windows\System32 as the root path.
I opened a cmd as admin and did a manual CD to the directory before running it, that seemed to do the trick (or at least, no errors, I haven't tested it's working yet :))
Weird... Can you try run the Install version in a new folder :/ Hopefully its just something to do with your specific machine as I didnt have the issue on mine. Though if its common then theirs not much I'm going to be able to do to fix it...
~ Main Rig ~
~ Accessories ~
~ Servers ~
1 minute ago, jt999 said:
Not sure what's happened, I now have some files in a folder called update, but the original files are untouched. I'll revert and try your update again :)
Download the new update.zip. It should fix that bug
~ Main Rig ~
~ Accessories ~
~ Servers ~
Just tried, no luck. I noticed I still get an error during update, although it finishes everything else
(node:6080) [DEP0013] DeprecationWarning: Calling an asynchronous function without callback is deprecated.
I'm running Server 2012 R2, perhaps that's the issue here :)
That error is fine. If that's the only thing your getting then it should be updating correctly. Can you check your settings.json file and see if the version is 3.4.0?
Also would you like to talk on discord instead of the form. Would be alot easier to try and sort this out :)
~ Main Rig ~
~ Accessories ~
~ Servers ~
Worked it out, I had to copy the files from update to the root folder (which included the settings.json), put my path in there and rerun it, now downloading again. I'll log into discord if I can - I'm meant to be working haha :)
Thank you for your help, you're a genius :)
That's fine, though it should migrate the stuff in the update folder into the main folder by itself and then remove the update folder... Hopefully it just works normally for everyone else :) I'm probably going to be pushing out a small update soon anyway to resolve some of these bugs and fix another issue I missed... Its been a long day xD
~ Main Rig ~
~ Accessories ~
~ Servers ~
4 minutes ago, jt999 said:
-Snip-
Nevermind I broke something with the new update to the update.zip.... So its not removing the files for some reason -_-... Ill work on fixing it now
~ Main Rig ~
~ Accessories ~
~ Servers ~
4 minutes ago, Shadow1232 said:
I'm Curious B|B|
That was the 3.4.0 Update... However That did and still does have a bunch of issues that were not fixed relating to bulk downloads and MAJOR issues with the update and install scripts, mainly due to them being the first version that I wrote yesterday... So There is actually another update coming quite soon... Will also overhaul the download info to look alot nicer. So you can look forward to that sometime soon...
Snek Pek:
~ Main Rig ~
~ Accessories ~
~ Servers ~
Just an update for you, I managed to get it working, here is what I did:
Downloaded manual.zip and extracted it
Manually ran npm install
CES downloads failed, settings json mentioned version 3.3.0 rather than 3.4.0 which was odd
Downloaded update.zip
Applied update.zip
All good after that :)
It might be something to do with my setup though, I'll try it on a different server (I'm looking to migrate to a newer OS anyway) and catch you on discord :)
-Snip-
Its probably 50/50 At this point tbh. The update file worked fine but there is a bunch of stuff that's kinda icky about it... I'm going to be working on putting out a better version of it soon hopefully.
~ Main Rig ~
~ Accessories ~
~ Servers ~
Snek Pek:
Oh nice, I like the new download loader, Better than the loader that we use now. But 3.4.0 run great. I run the update file and i it work, The only problem that I had been that all the video files named with the datum. I remove the "Linus Tech Tips" files in the folder and download it again en now everything works fine. Also, the CES files. And jt999 I use windows server 2016.
Version 3.5.0 (GitHub)
The 3.5.0 Release is out...
This release was pushed out a bit earlier than originally planed due to some issues 3.4.0 had with its update scripts. Hopefully this version should be a lot more stable.
Changelog
v3.5.0
  • Rewrote downloading display to better support multiple videos & sexy loading bar.
v3.4.1
  • Fixed issues with update & install scripts
  • Fixed MultiPage Downloads incorrectly organising videos
Install Guide
If your updating then just download the Update.zip extract it to your install folder and run it. It will automagically update all the needed files and move your settings over.
I suggest double checking that everything is correctly updated in the settings.json though it should move your old settings over.
Install.zip
Update.zip
3.5.0.zip
~ Main Rig ~
~ Accessories ~
~ Servers ~
So... This has gotta be the longest time I have spent working on this script straight lol. Pretty sure I hit around 14 hours at least :P.
Anyway please do test the update script and the main script as while I was more rigorous with them when fixing them in 3.5.0 there are always issues...
I figured id do a little thing about some plans I might consider for the script in the future... So do give me some feedback on what you think of these ideas.
I have been considering for a while to give the script a local website interface, mainly for easily changing settings for people who don't know how to, but possibly also as a replacement for plex if you didn't want to use plex.
Another thing I was considering doing is compiling it for Android so that you could download using the script on your phone if you were on the go.
Other than that its just small updates and new features when I think of them :) I'm always open to contributions and recommendations though xD
Anyway hope the new update works well for everyone! Ill be lurking <3
o/
~ Main Rig ~
~ Accessories ~
~ Servers ~
