Look i feel quite dumb not knowing how to troubleshoot this but...
DRAM, and CPU lights are both on
Ram is seated very well, CPU PINS are in aswell all the way?
Any help trying to get this fixed asap!
twitter if anyone can help via DM, @forgivingage
System:  Ryzen 7 1800x, GTX 1070 8GB, MSI x370 SLI PLUS, CORSAIR LPX 4x 4GB 3000mhz, MASTERBOX 5, EVGA 650W G2, WD 250GB M.2
Links:
Youtube
Twitter
Discord
PCPP
Twitch
https://linustechtips.com/topic/857670-need-some-help-aye/
What's the problem?
"Those who are last are sideways and smiling". - Jeremy Clarkson
https://linustechtips.com/topic/857670-need-some-help-aye/#findComment-10677161
1 minute ago, NPSTR107 said:
What's the problem?
Lol so stressed forgot to add it, systems not posting / video out putting
Links:
Youtube
Twitter
Discord
PCPP
Twitch
https://linustechtips.com/topic/857670-need-some-help-aye/#findComment-10677169
Just now, Inf3cted_Worm said:
Okay so firstly simple stuff, GPU is seated properly? Check the power connectors are all geezy and unplug everything except power and display.
Have you got any spare RAM to throw in and check, dead RAM can definitely halt a post
I dont have any spare ram but i have 2 stick off 4g Corsair LPX 3000mh when i take the second out both the CPU and DRAM light go off yet i still dont get a post....
Links:
Youtube
Twitter
Discord
PCPP
Twitch
https://linustechtips.com/topic/857670-need-some-help-aye/#findComment-10677250
