PSU broke need help!
Solved by Windows7ge,
So long at it's using what I assume is the ATX form factor and has the appropriate number of connector with enough Amps on the 12V rail for the GPU then you're free to use anything you so choose.
However if there's one thing you don't want to cheap out on it's the PSU. I'd recommend buying another Corsair 750W (does not have to be the CX series) because it's a reputable brand and 750W will allow room for more drives and more powerful GPUs. Also it can be used in later builds if you choose to run SLI or upgrade the motherboard/CPU or what to try overclocking.
