8700K Temps
Go to solution Solved by Nosfy,
1 minute ago, BryceJonathan said:
Like 70C is more than acceptable. If you were spiking up into the 90s thats when you should sworry. You are perfectly fine. Kind of shocking that you havent seen temps that high before.
Well I never overlocked before. Thanks for putting my mind at ease :)
Hi.
So i just got a new 8700K on a Aorus Gaming 7 with a H100i V2.
Was playing Assasins Creed Origins on high settings and the CPU temp was running 67-70C. I have never had a CPU run this hot so wondering if I should be worried. It is also idling at anywhere between 37-40c
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/857560-8700k-temps/
Anything below 85C is safe.
https://linustechtips.com/topic/857560-8700k-temps/#findComment-10676142
System Specs
CPU: I7-5820k   MOBO:Asus X99 strix   RAM: 32gb corsair Dominator Platinum 2666mhz   GPU: Gigabyte G1 Gaming 980TI  PSU: Corsair RM1000i
https://pcpartpicker.com/list/mg7k2R
https://linustechtips.com/topic/857560-8700k-temps/#findComment-10676182
https://linustechtips.com/topic/857560-8700k-temps/#findComment-10676189
That idle sounds high.  Are you running manual voltage or offset?
i9-9900k @ 5.1GHz || EVGA 3080 ti FTW3 EK Cooled || EVGA z390 Dark || G.Skill TridentZ 32gb 4000MHz C16
 970 Pro 1tb || 860 Evo 2tb || BeQuiet Dark Base Pro 900 || EVGA P2 1200w || AOC Agon AG352UCG
Cooled by: Heatkiller || Hardware Labs || Bitspower || Noctua || EKWB
https://linustechtips.com/topic/857560-8700k-temps/#findComment-10676195
