Best microphone for 50$ +-
Hi guys,
i`m looking for a michrophone under 50 $,
i saw these:
1: https://www.amazon.com/dp/B073VJV1RH/ref=twister_B071WP5DJN?_encoding=UTF8&psc=1
2: https://www.amazon.com/dp/B01HTMA69Q/ref=twister_B076H3Y3XX?_encoding=UTF8&th=1
some videos included these, i wouldnt mind something with xlr so i can upgrade with a dac and then a better mic
any tips? or better mics?
ty in advance
https://linustechtips.com/topic/857099-best-microphone-for-50/
6 minutes ago, ImHyperstyle said:
neewer isn't very good btw the other one idk though
If you want to use either of them you need a Audio Interface for the phantom power which will run you at least 100 bucks.Most XLR mics require this
Just get a blue yeti
My life
https://linustechtips.com/topic/857099-best-microphone-for-50/#findComment-10671292
the phantom power will power it and provide an xlr to 3.5 mm jack
https://linustechtips.com/topic/857099-best-microphone-for-50/#findComment-10671303
In general, the phantom power kits are garbage.  A Behringer UMC-22 would provide Phantom power, as well as a reasonably good quality Midas preamp for the mic, for about $40US.  I generally hate Behringer gear... but for the price you really can't do any better.  Buying Midas was the best business move they've ever made.
That's your interface... way more functionality than the power injector for the same price.
https://linustechtips.com/topic/857099-best-microphone-for-50/#findComment-10671342
can you send me a link?
https://linustechtips.com/topic/857099-best-microphone-for-50/#findComment-10671354
https://www.amazon.com/Behringer-UMC22-BEHRINGER-U-PHORIA/dp/B00FFIGZF6
Check around on youtube for some demos of it.  There's even some examples of the Neewer mic you listed running through this and it doesn't sound half bad.
If I may ask, what are you planning to use the mic for?  Just voice-over/podcast type stuff, for instrument recording, for streaming, etc?
https://linustechtips.com/topic/857099-best-microphone-for-50/#findComment-10671365
This guy does a fair number of reviews of inexpensive mics and interfaces.  Here's some coverage of the UMC-22.  Check out some of his other stuff, as he has tons of samples.
Really, for Discord/teamspeak... I'd probably go with a headset mic to help cut out background noise.  A ModMic would be fantastic for that application, assuming you're already wearing headphones.
Otherwise, just about any decent mic through a decent interface would be more than enough coverage and clarity.  (alternatively, a Yeti or Snowball would do the job and be USB).
https://linustechtips.com/topic/857099-best-microphone-for-50/#findComment-10671444
Work Desktop: Dell Precision 5810 | Intel Xeon E5-1607 v4 | 8GB 2400 MHz ECC DDR4 | AMD FirePro w5100 4GB GDDR5
Laptop: MacBook Pro 15" | Intel i7-4870HQ | 16GB 1600 MHz DDR3 | Nividia GeForce GT 750M 2GB GDDR5
https://linustechtips.com/topic/857099-best-microphone-for-50/#findComment-10671798
Our ModMic may also fit your needs surprisingly well, if you really want to go XLR you should certainly start by watching Podcastage's stuff (the video @csanders linked above). It depends on what your goal is. If you really want to get into professional stuff you're likely going to replace a "50 dollar" mic pretty quickly after you upgrade to a mixer/amp setup, so personally I wouldn't fret over XLR at this stage. When you're ready to upgrade your audio setup do it all at once and give yourself plenty of time to research. Otherwise you'll get a cheap bit now and a cheap bit later and have to keep replacing things.
For 50 bucks you can get a decent mic, ours, the Snowball, as two options stated here. That will serve you really well for a long time and let you decide if you really need to go bigger.
Director of Marketing for Antlion Audio, creators of the ModMic.
More info at www.ModMic.com
Ask questions, I'm friendly!
https://linustechtips.com/topic/857099-best-microphone-for-50/#findComment-10674689
  • 2 weeks later...
i found a logitech g35 headset to fullfill my full needs of a new headphone and a new mic (:
https://linustechtips.com/topic/857099-best-microphone-for-50/#findComment-10710331
