I'm stuck on a decision! Need Help!!
Solved by Encrypt,
I would say get a better motherboard and a CPU. I doubt you'd be able to get good overclocks on your current motherboard, so get a decent overclockable motherboard and the i5-8600K. You will still need an AIO or good air cooler to overclock on it, but the i5 will give you ample performance until you can afford a better cooler.
Featured Topics
eric_s ·
Posted in Power Supplies0 -
1
Silencix ·
Posted in Cases and Mods1 -
4
LambdaBird ·
Posted in General Discussion5 -
2
12
4
2
joe_ollie909 ·
Posted in CPUs, Motherboards, and Memory8
