Paste temp difference? StarTech Metal Oxide Vs. Arctic MX4
Solved by phongle123,
Basically Thermal paste comes in 2 different types that you can get. You can't have both, but you can come pretty darn close and pick the best one.
1) Lowest Temperature
2) Highest Accuracy
1) You can get the best thermal paste/grease to lower your temperature. Meaning the grease needs to be of higher quality and can withstand and transfer heat faster.
2) Accuracy relates to the amount of discrepancies your temperature has.
For example:
- Grease 1 (lowest temperature): 40C (low), bounces between 40C and 47C.
- Grease 2 (Highest Accuracy): 43C (low), bounces between 43C and 45C.
