Open space in front of case fan air intake?
iSarge
I need to know how much free, unobstructed space do I need, at a minimum, in front of a case fan intake.  I'm running out of room with my Fractal Design Define Mini (mATX) case.  Will 20mm suffice for the following fan?
Cryorig XT140 140mm x 140mm x 15mm
By in front, I'm assuming you mean between the case fan and the rest of the components inside the case, not the front of the case.
I don't think it really matters too much, I've seen builds with hard drives all the way up the front of the case right behind the fans
If you have 20mm in front of your fan clear that might just do.
But if you have 20mm to stick a 15mm fan in leaving 5mm that's not enough.
Quote
CPU-AMD Ryzen 9 5900X / CPU Cooler-Noctua NH-D15S / Motherboard-MSI MPG X570S CARBON MAX WIFI / Memory-G.Skill Trident Z Neo 64 GB (4 x 16 GB) DDR4-3600 CL16 / Storage-WD WDBSLA0040HNC-NRSN 4TB 3.5" 7200 RPM / Storage-WD Red 6 TB 3.5" 5400 RPM--Crucial P3 4TB 3.0X4 NVME--Sabrent Rocket 4.0 1TB 4.0X4 NVME--Corsair MP600 CORE 2TB 4.0X4 NVME / Video Card-XFX Radeon RX 6900 XT / Case-Lian Li O11 Air Mini / PSU-SeaSonic PRIME 1000 W 80+ Gold / Sound Card-Creative Labs Sound Blaster Z w/Shield / Monitor-BenQ GW2765HT 27.0" 2560 x 1440 60 Hz / Monitor-Asus ROG Strix XG27AQ 27.0" 2560 x 1440 170 Hz / Keyboard-Logitech G Pro / Mouse-Logitech G502 LIGHTSPEED Wireless / UPS-CyberPower GX1325U / Fan Controller-Corsair Commander Pro
Quote
CPU-AMD Ryzen 7 5800X / CPU Cooler-Corsair iCUE H100i ELITE CAPELLIX / Motherboard-Asus TUF GAMING X570-PRO (WI-FI) / MemoryG.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL16 / Storage-Western Digital Black SN750 SE 1TB 4.0X4 NVME--Samsung 970 Evo Plus 2TB 3.0X4 NVME--Seagate Barracuda Compute 3 TB 3.5" 5400 RPM / Video Card-Asus KO Gaming OC GeForce RTX 3070 / Case-Lian Li O11 Air Mini / Case-LIAN LI PCI-E 16 X 4.0 Black Riser / PSU-EVGA SuperNOVA 850 G+ Gold / Monitor-LG 22BK430H-B 21.5" 1920 x 1080 60 Hz / Monitor-MSI Optix 271CQP 27.0" 2560 x 1440 165 Hz Curved / Keyboard-Logitech G413 TKL SE / Mouse-Logitech G502 HERO Wired / UPS-CyberPower CP1350PFCLCD / Fan Controller-Corsair  Commander Pro / Sony HT-S200F Soundbar
Quote
CPU-AMD Ryzen 7 5700X / CPU Cooler-Scythe Mugen 5 Black Edition / Motherboard-MSI MPG B550I GAMING EDGE MAX WIFI / Memory-G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 / Storage-Samsung 970 Evo Plus 1TB 3.0X4 NVME--PNY CS900 1TB 2.5" SSD--Samsung 970 Evo Plus 2TB NVME/ Video Card-EVGA XC GAMING GeForce RTX 3060 / Case-Cooler NR200P / PSU-Cooler Master V750 SFX GOLD / Keyboard-HyperX Alloy Origins Core / Mouse-Logitech G502 HERO Wired / UPS-CyberPower LE1000DG-FC / Fan Controller-NZXT RGB & Fan Controller
Quote
CPU-AMD Ryzen 7 5700G / CPU Cooler-Scythe Shuriken 2 / Motherboard-Gigabyte X570 I AORUS PRO WIFI / Memory-Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3800 CL18 / Storage-WD Blue 1TB 2.5" SSD--Samsung 970 Evo Plus 1TB 3.0X4 NVME--Patriot P310 1.92TB 3.0X4 NVME / Case-InWin B1 Mesh / Keyboard-Logitech K380 / Mouse-Logitech G502 LIGHTSPEED Wireless / Monitor-ViewSonic VX1755 17" 1080p Portable IPS Gaming Monitor 144Hz / Speakers-Creative Muvo Go (Black)
As long as they're not in the fans and you aren't obstructing all the air flow (because then you might as well have no fan...) you'll be fine. There's no rule for this.
That's an F in the profile pic
But you just stated some "rules" before saying "There's no rule for this.".xD
Quote
Quote
Quote
Quote
Bear in mind that's a 140mm fan that uses 120mm mounting holes. Depending on spacing between fan mounts, it could conflict with another installed fan (example: if the spacing is correct for a 240mm radiator, then you can not mount two of these 140mm fans, even if the case accepts 280mm radiators as well. You could also have troubles fitting a standard 140mm and this 140mm next to each other for the same reason).
Hmm, from what I could tell OP was asking if they have to have a minimum open amount of space in front of the fan. You're right, but AFAIK that's not what OP is asking. It wasn't phrased incredibly well.
It's the one rule that should apply to everything - common sense xD
But common sense is uncommon, you can't count on it.:)
Quote
Quote
Quote
Quote
I know it's not what he's asking. I'm just warning him, since his case has 2 front fan mounts and he could end up with a fan that doesn't fit regardless of thickness.
I have an S340 which has a restrictive panel like the Fractal mini.
I heavily modded the front panel by removing it completely.
Looks good and great airflow.:)
Quote
Quote
Quote
Quote
it is for a cryorig H5 Ultimate cpu cooler.  what i'm doing is turning the H5 ultimate, so that its orientation is drawing air from the low side of the case and expelling air directly to the top of the case.  to clarify, the first gpu slot in the mobo is occupied by a video card.  so, we have the back of the video card facing the air intake of the H5U bottom side fan.  so the basic question of post#1 holds true and by the looks of things, the question has already been addressed.  feel free to comment further if you feel motivated.
nice job there wonk, looks good and i'm certain functions very well.
Doesn't matter at all in temps. I used to run that config in previous case. You can hear people claiming that GPU somehow radiates heat from backplate/PCB to CPU cooler. But in 4 years I run that, I didn't notice anything.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Thank you all for your comments, much appreciated!
