Hey. I just got the news that my Dad is getting our house 300mbps internet from Virgin Media here in the UK. Now, my current internet speed is 15mbps. So I wanted to know, in terms of reality, what will this change feel like?
I know I will be able to download games and whatever at ludicrous speeds, but I've never experienced this sort of speed. ever. If someone is able to do the math, how long would a typical 30GB - 40GB game take to download? When it currently takes anywhere between 5-7 hours? I'm honestly super excited for this internet speed as I will be able to do anything I want lol.
Also the upload is around 20Mbps. Would that mean I could live stream in 1080p and still have loads of bandwidth left over?
CPU: Intel Core i7 8700
GPU: Gigabyte GeForce GTX 1070
MOBO: ASUS Z370-F STRIX
RAM: 16GB Corsair Vengeance DDR4 2133MHz
https://linustechtips.com/topic/856171-300-megabit-per-second/
well, to put it bluntly 300mbps is freaking fast, but if you ever end up downgrading or using public hotspots you'll be in pain
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/856171-300-megabit-per-second/#findComment-10661209
Yeah that is pretty decent download speed, I currently have a 100mbps and it is more than enough for me. Streams 4k just fine. But you are missing an important part of the puzzle here, not all your devices will support this kind of download. So unless you are running an Ethernet cable to your desktop (which I strongly recommend), I'd go on Amazon and buy a nice PCI-e wireless card for your desktop.
GPU: XFX RX 7900 XTX
CPU: Ryzen 7 7800X3D
https://linustechtips.com/topic/856171-300-megabit-per-second/#findComment-10661211
1 minute ago, jt999 said:
A 35GB game would take around 15 minutes at 300Mbps
That's bloody insane!
You'll easily see the difference from 15Mbps for downloads of any kind.
I get that, but I honestly can't wait to see the typical 40 minutes for a 5GB file turn into something like a minute.
https://linustechtips.com/topic/856171-300-megabit-per-second/#findComment-10661213
Regarding the download speeds, it will be better in some cases, but not all. A lot of servers (such as the ones serving Google Drive) are fast enough, but not all. For some sites you may not notice an increase in download speed at all.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/856171-300-megabit-per-second/#findComment-10661215
Running cat5e to my switch and Desktop. Will need to get a Gigabit switch though as it's maximum is 100mbps
https://linustechtips.com/topic/856171-300-megabit-per-second/#findComment-10661216
This site is good for calculating file transfer times http://www.calctool.org/CALC/prof/computing/transfer_time
https://linustechtips.com/topic/856171-300-megabit-per-second/#findComment-10661223
That's only theoretical, and even so, you won't get that from a LOT of servers online.
Main System: Phobos
https://linustechtips.com/topic/856171-300-megabit-per-second/#findComment-10661243
While downloading one thing at once will only be noticeable if supported, the largest improvement for me was what I could do in parallel. Sometimes when working on large projects that involve getting bits and pieces from other collaborators, I could be downloading multiple large files at once. Rather than having to "wait in line" getting all the pieces at the same time saved a ton of time.
https://linustechtips.com/topic/856171-300-megabit-per-second/#findComment-10661249
Hey, that is why I pay for Real-Debrid. They download the file you want (or torrent) and then once they have it hosted on their server, you download it from them at a solid and uninterrupted 300mbps.
https://linustechtips.com/topic/856171-300-megabit-per-second/#findComment-10661253
True, but it's a good indication if you're able to find a lucky server. I download Microsoft ISO files a lot at work on 1Gbps link and it maxes out nicely :)
https://linustechtips.com/topic/856171-300-megabit-per-second/#findComment-10661416
