I have a AMD 380x nitro and it will randomly spin fans up to 100% about 10sec to 1min before the system just Turns off. (Black screen Desktop off)
It is completely unstable when given more power or playing with the overclock setting any ideas?
the temp will read 0*C sometimes and on boot sometime the fans start @ 100% and will have to be menualy tuned down in settings.
Specs
CPU: AMD FX 8320 (Corsair h100i cooler)
Motherboard: ASUS M5A97 R2.0 Bios 1603 version
GPU: 380X nitro
PSU: Courger 1000W gold
Tryed
Cleaning PCI slot and card pins
Reinstall of AMD drivers (clean Install)
Reinstall of windows to make sure.
https://linustechtips.com/topic/855966-380x-issue/
I had this issue with my 5870, and from what you're describing, it's a dying card. Again, maybe I'm misinterpreting your problem, maybe a video would help.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/855966-380x-issue/#findComment-10658886
Specs
GPU: 380X nitro
Tryed
Take off any overclock and restore it to factory defaults.
Since you've voided your warranty, if this doesn't help open it up, clean it, replace thermal pads and thermal paste. Test the card again at stock speeds.
https://linustechtips.com/topic/855966-380x-issue/#findComment-10658890
I happens quickly and randomly i be mid game or what ever and the all i hear is the GPU spin to 100% then followed by a black screen but will boot sometime with the fans on %100 and will have to be turn down manually
ALSO I FORGOT TO ADD
https://linustechtips.com/topic/855966-380x-issue/#findComment-10658895
Try the card on a different PC. I've seen such problems with either the graphics card (VRM) being faulty or a faulty PSU causing power surges to the GPU.
Have you tried running FurMark or Unigine Heaven and monitoring the temperatures?
I have a Nitro 380X too.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/855966-380x-issue/#findComment-10658911
I ran Fur mark temps max at around 75 *c
https://linustechtips.com/topic/855966-380x-issue/#findComment-10658912
