2 minutes ago, NovaMan01 said:
I need slim fans for a H110i radiator to ftit in a Fractal Design Mini C with a Strix 1060. Any suggestions? They need to be under 15 mm thick. I was looking at these: https://www.newegg.com/Product/Product.aspx?item=9SIA68V21E0614
these are really your only option
http://www.frozencpu.com/cat/l3/g36/c15/s972/list/p1/Fans-12_Volt_Fans-120mm_x_12mm_Fans-Page1.html
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
https://linustechtips.com/topic/855772-need-slim-fanbois/#findComment-10656790
Just now, Majestic said:
Those are the same on their VGA coolers, wasn't really impressed by those. And there are still these btw:
http://noctua.at/en/products/fan/nf-a12x15-flx
he said under 15mm thick, those are 15mm thick, maybe they are ok and he meant max 15mm thick?
https://linustechtips.com/topic/855772-need-slim-fanbois/#findComment-10656815
These are pretty great https://www.newegg.com/Product/Product.aspx?Item=9SIA66Z28S3552
I Bought one to replace a slim prolimotech fan I had that was going bad, it works quite well as an air intake fan although you might want the prolimotech fan if static pressure is what you desire https://www.newegg.com/Product/Product.aspx?Item=9SIA85V6DP5026&cm_re=prolimotech-_-9SIA85V6DP5026-_-Product
alternatively you could get a slimmer rad AIO instead and buy a better 25mm thick fan
https://pcpartpicker.com/product/TDdFf7/cooler-master-masterliquid-lite-120-667-cfm-liquid-cpu-cooler-mlw-d12m-a20pw-r1
https://pcpartpicker.com/product/9gRFf7/cooler-master-masterliquid-lite-240-667-cfm-liquid-cpu-cooler-mlw-d24m-a20pw-r1
https://linustechtips.com/topic/855772-need-slim-fanbois/#findComment-10656879
