Hello!
Today I seek help about a problem I am having with my Realtek drivers. Whenever I plug an Ethernet cord into my computer no light turns on and it doesn't get detected and looks like this https://imgur.com/a/YxIJs I am hoping somebody can assist me. I really hope my mobo isn't a defective one as I recently got it as an upgrade (original system had ddr3 memory, intel pentium, foxconn mobo).
Specs:
- AMD Ryzen 7 1700 CPU
- ASRock AB350M Pro4 (Bios Version P3.10 newest)
- Kingston SSDNow UV400 480GB and Seagate Barracuda 500GB 7200RPM HDrive
- Gigabyte GTX 960 OC WindForce
- ThermalTake TR2 600W ATX PSU
- Crucial 8GB DDR4-2400 Ram
- Windows 10 64 bit
I have tried:
- uninstalling and reinstalling drivers
- restarting computer
- downgrading version of drivers
- updating drivers
- updating bios from 3.0 to 3.10
- different ethernet cords and outlits
Screen Shots:
https://imgur.com/a/2v7N6
https://imgur.com/a/l3TrN - Netgear is currently my USB Wifi Stick
https://imgur.com/a/0yNyv
BasedMD CPU
https://linustechtips.com/topic/855755-realtek-ethernet-driver-problems/
turn on wake from lan (BIOS)
take out ethernet
turn off pc
plug in ethernet
if it doesn't wake, it broke.
i really have no idea if this will work or not, as i've never used wake from lan, and found that to be a useless 'feature' but..
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
11 minutes ago, themctipers said:
  Reveal hidden contents
take out ethernet
turn off pc
plug in ethernet
Hey,
it didn't work. I'm just gonna go cry now.
I could just go get a usb to ethernet right?
BasedMD CPU
2 minutes ago, AncientEntity said:
Hey,
RMA!!
Hmm weird, I have the exact same motherboard and have had absoloutely no problems with my ethernet at all.
Have you previously had it working at all?
Go into bios and there's an option in there to update ethernet driver...  also have a look in your network settings to see if something doesn't look right.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
Whats the option called?
Previously I was using and still am a wifi USB stick and I haven't really had the chance to use it until now.
BasedMD CPU
Have a look through the bios options, it's on the 3rd tab IIRC, I'm not rebooting my system to see what it's called for you, it's clearly labelled.
The other thing it could be is your network settings, go into [all settings] - [network and internet] - [ethernet]
click on [network]  under the ethernet/ethernet heading... yours will most likely say not connected and will look like the ethernet network icon same as in the taskbar.
Under [make this pc discoverable] there is a toggle switch, change that to [ON]
Also, you need to make sure that the network cable you are using and port you are using on the router are working... if you have another ethernet device plug that in and see if you get a connection.
If you don't have another ethernet device, you'll have to try different router ports instead, to see if you accidentally plugged it into the wan port or something.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Hmm I cant seem to find the bios option...
But I will try the other idea!
BasedMD CPU
