- Get better CPU for editing (Ryzen 7 1700 would be ok IMO)
-Get more RAM for editing
- Do you need 1080 for gaming (do you want 1440p/4k)? If you want to play 1080p then 1060 6GB or 1070 (or 1070Ti) would be better
- 750W probably a bit of an overkill. (But not sure how much Ryzen + 1080 would draw)
Try, fail, learn, repeat...
https://linustechtips.com/topic/855544-first-pc-build-help/#findComment-10654460
might get a better CPU, and more ram (32 gb preferably).
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/855544-first-pc-build-help/#findComment-10654464
Which programs will you use for photo and video editing? For Adobe CC, depending on the use case, a Coffee Lake I5/I7 might perform better. For gaming, an 8400 will perform better.
The R5 is a fairly old case. There are plenty of newer and better ones, unless you absolutely need that many HDDs.
750W is way overkill. 450-650W is fine.
Do you really need a Blu-ray player?
https://linustechtips.com/topic/855544-first-pc-build-help/#findComment-10654473
Ah, I inherited a Dell S2716DG so I thought that the 1080 might be better for that.
https://linustechtips.com/topic/855544-first-pc-build-help/#findComment-10654482
Mainly Adobe Photoshop and premier, as well as less intensive stuff like Virtualdub. For gaming anything from AAA releases to things like Europa Universalis 4.
To be honest I choose the case as I liked the look of it-I hadn't quite realized how old it was though!
Thanks, I will correct that.
Ideally as my old Blu-ray player broke and this seems like a economical way to replace it.
https://linustechtips.com/topic/855544-first-pc-build-help/#findComment-10654526
Depending on what you'll do in Premiere and Photoshop, a Coffee Lake can perform better. Check out Puget's testing.
https://www.pugetsystems.com/labs/articles/Photoshop-CC-2017-1-1-CPU-Performance-Core-i7-8700K-i5-8600K-i3-8350K-1057/
https://www.pugetsystems.com/labs/articles/Premiere-Pro-CC-2017-1-2-CPU-Performance-Core-i7-8700K-i5-8600K-i3-8350K-1047/
https://linustechtips.com/topic/855544-first-pc-build-help/#findComment-10654554
35 minutes ago, seon123 said:
That's very helpful, thank you very much :)
https://linustechtips.com/topic/855544-first-pc-build-help/#findComment-10654660
