Help removing ram
Go to solution Solved by 79wjd,
  1. Push the clip towards the motherboard
  2. Image result for firmly grasp it
  3. Pull
  3. Pull
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/855345-help-removing-ram/#findComment-10652220
push the slot back
pull
hate yourself when your hand inevitably hits something sharp and you cut yourself
start to build up a hatret for these one side clip slots
done
Builds:
https://linustechtips.com/topic/855345-help-removing-ram/#findComment-10652242
