3 minutes ago, XxMLGMASTERxX said:
I want to build a gaming rig with an fx 6350 what cooler should I get it should cost around 20 to 30 € or $
 If possible.
Just a hint: FX series is ancient and everyone should keep away from it. Make yourself a favor and buy the new amd Ryzen or the new Intel processors.
https://linustechtips.com/topic/855332-what-cpu-cooler/#findComment-10652145
 If possible.
Yes, don't go with FX, it is outdated and has horrible performance, even if it is very cheap.
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
https://linustechtips.com/topic/855332-what-cpu-cooler/#findComment-10652154
Just now, XxMLGMASTERxX said:
An 2700k is also outdated
First of all, that's not the point.
Second of all, I got this cpu&Mobo for free.
Third of all it has much better performance both multi and single threaded performance than any FX processor.
Fourth of all fx processors are very power inefficient.
https://linustechtips.com/topic/855332-what-cpu-cooler/#findComment-10652180
Where are you shopping/located?
https://linustechtips.com/topic/855332-what-cpu-cooler/#findComment-10658203
