If there is no issue or whats there works don't update the bios. Either just try running the .exe and see what happens (I would do that) or have a look in the manual, if you didn't get the update off the motherboard support page then don't run it as it will probably be a trojan.
Have you tried turning it off and on again?
https://linustechtips.com/topic/853500-help/#findComment-10630920
Just now, tmorga67 said:
if I update my bios on a different hard drive and switch back would that work
As long as that HDD is in that machine I don't see why not. Make sure that the application is 32 bit if you have 32 bit windows and 64bit for 64bit windows first.
https://linustechtips.com/topic/853500-help/#findComment-10631003
dell.com XPS 435mt bios update
Do you have a USB flash drive or anything like that? If so, go to
http://www.dell.com/support/article/uk/en/ukdhs1/sln143196/how-to-create-a-bootable-usb-flash-drive-using-dell-diagnostic-deployment-package--dddp-?lang=en
Do that, then do what it says in section 6 in the below link
http://www.dell.com/support/article/uk/en/ukbsdt1/sln284433/what-is-bios-and-how-to-update-the-bios-on-your-dell-system?lang=en
As you don't have to boot in to windows to do it.
If you have bitlocker enabled, read section 5 in the 2nd link
https://linustechtips.com/topic/853500-help/#findComment-10631024
Hmmmm.... can I get a link to the specs of the mobo? And I'll call in another Xeon homie, @WhisperingKnickers.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/853500-help/#findComment-10631648
double check to make sure the socket pins aren't bent. Was the machine working before you put this xeon in it?
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
https://linustechtips.com/topic/853500-help/#findComment-10631665
