Le What?
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1159177
Le What?
I have a 3rd rig with 4x 6950s. If I use anything over 12 intensity they get HW errors. Otherwise, im getting around 240k per card. (My 290X's get 860 each  :lol:)
Research and Development at Digital Storm
Personal Website: www.DigitalNav.net
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1159193
Am I not making sense?  :huh:
12 Intensity?
   Hail Sithis!
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1159222
-I 12
Yep, still haven't got a clue.
   Hail Sithis!
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1159235
What settings are you guys using? If I use anything over  12 Intensity it gets tons of HW.
What are you current settings?
Try something like this
clocks: 900/1250
cgminer.exe --scrypt -i 19 -w 256 --thread-concurrency 8192
Don't run them in crossfire either.
You keep using that word. I do not think it means what you think it means.
Users cannot, and will not securely manage key material. Most users can't and the ones that can, wont.
Ask me about Bitcoin, Litecoin, Crypto-Currencies, and/or Mining them.
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1159237
clocks: 900/1250
Yeah there not crossfired. Ill try that after.
Currently its set to -d 0,1,2,3 -I 12,12,12,12
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1159246
another thread concurrency to try would be 14208
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1159259
On all 4 cards?
Also, should mention. 3x are XFX card and one is a MSI Twin FRZR
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1159656
I run 2 6950s, one unlocked to a 6970. I use:
925/1250, -i 18, -w 256, thread concurrency 8192. Be sure to use 2 GPU threads.
Main rig: i7 3770K @ 4.54, Sapphire R9 290, Sabertooth Z77, 16 GB Mushkin Redline 2133, Lian Li PC-P50R, Seasonic 860xp Platinum, Kingston Hyper X 3K 240GB
freeNAS server: AMD Athlon II 170u 20W, 5 x 3TB WD Red in raid-z1 (12 TB)
media centre: AMD A10-5700, crucial M4 (boot), running XBMC,4 x 3TB WD Red, 3 x 3TB WD green + 2TB green in FlexRAID (17 TB)
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1159737
hash rate?
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1160186
hash rate?
440kh for the msi 6950, 485kh for the sapphire unlocked to 6970
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1160294
So im missing out on about 500 khash :(
Have you tried 2 gpu threads?
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1160360
-g 2?
yes
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1160422
I have a MSI Twin frozr OC edition Radeon HD 6950 2GB.
Overclocked to 840mhz on core clock, 1325mhz on memory clock. Intensity 13 gets me 290 kilohashes.
Intensity 20 gets me 420. Currently using Intensity 13 because 20 lags up my system like hell. 13 is the highest it can go without screwing up everything and making it lag.
Use this as a reference https://litecoin.info/Mining_hardware_comparison
Folding for LTT since April 2016.
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1162253
Holy crap how are u getting 440kh? Is it on intensity 20? If it is, for me on intensity 20, my MSI 6950 (twin frozr 2gb) is only getting 420kh , on 840mhz  core clock and 1325mhz memory clock.
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1162304
intensity 18.  I might be able to get an extra 10 kh on -i 20, but its not worth the extra stress on the GPU. I find it runs best on stock memory of 1250, overclocking it actually brings the hash rate down.
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1162637
I take it back, i18 gets a ton of HW (which im assuming means hardware error?)
Gonna try a lower intensity, overclocking helps hash rate for me.
https://linustechtips.com/topic/85239-anyone-running-6950s/#findComment-1163039
