I have a old athlon x2 245 on a dell motherboard, when I turn the computer on all that fans spin up except for the exhaust fan, I also get no video output. I disconnected the cpu and the same thing happens. Is this the motherboard problem or a cpu probelm. (the cpu has small traces of thermal paste on it) (artic mx-4)
https://linustechtips.com/topic/852058-diagnostics-help/
On the pins
https://linustechtips.com/topic/852058-diagnostics-help/#findComment-10617103
disconnect everything, get a soft toothbrush and some isopropyl and clean gently E: and make sure to leave it to dry out for a while before you try slapping it back together
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/852058-diagnostics-help/#findComment-10617111
