Please help... I was looking through YouTube when I spilled water on my computer. No pop or juice. It got all inside the computer and mobo. I managed to unplug it within a second, but not before my audio died. There was still video output. I currently have it drying out now with a fan. What should I do? Will it be okay? When can I use it again?
It's also on the gpu
Thank you for your help.
13700k, 3070, 32GB@3200
https://linustechtips.com/topic/852053-water-spilled-on-computer/
probably a good idea to disconnect and separate everything, you're gonna want to make sure everything is absolutely dry before you try using it again
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
leave it to dry out, take off all coolers/ heat sinks and leave them to dry for a week or so (being cautious) and reapply thermal pads and thermalpaste.
just make sure its 100% dry before you test it, let it sit for days.  it will probably be fine, but any moisture and you start it up and it could die.
remember linus had his laptop soaked by the rain and he got it to work
If you want to argue with me, and you probably will please PM me, no need to ruin threads becase you dont like how I am.
Ask me how I made 100k selling illegal narcotics!
and you think im joking, Did a lot of wrong to get my money right.
I look up to Larry Hoover.
Your homies loyal 'til the one time you tell 'em no
Just now, Clockwork_princess said:
just make sure its 100% dry before you test it, it will probably be fine, but any moisture and you start it up and it could die.
don't remember but makes sense, as long as theres no electricity running through it when its wet it should be fine. but that begs the question it shouldn't work right? i mean water already got on it when running?
2 minutes ago, Aidanlockett1 said:
did it get in psu? can u put up pics?
It's not in the PSU.w
3 minutes ago, Aidanlockett1 said:
it dosen't look as if it got in cpu so that might be fine, also ram and psu should be fine
Since it's only on the mobo and gpu do you think I will have to take anything apart?
1 minute ago, Nickathom said:
Yeah worst case gpu and mobo are broken...
worst case, its all dead. If mobo shorts badly your fckd buuut since you turned it off fairly quickly id say you have a good chance that its only mobo that died. your one lucky ass, your gpu has a backplate, so water mightve reached it after you turned it off
Take everything apart and try to give the components an alcohol bath. You can use nearly any isopropyl and a squirt bottle. The alcohol should evaporate in a few hours, I usually leave parts hanging overnight, and then blow out the slots. Take care with the socket since you'll need it removed.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
before u use isopropyl alcohol make sure its 99 percent because most 70 percents have some percentage of water
Remove the CMOS battery right now. Any electricity at this point will cause corrosion.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
I don't think I need to remove the cpu cooler. There is not that much water around it. Though how would I bathe it... Like just pour alcohol on it? And what about the gpu? There's not very much and I'd prefer not to void the warranty assuming it still works as the video out never died.
isypropyl alcohol not water make sure its 90 percent.
Yeah I had a brain fart. But do I just pour the alcohol onto the parts? And will I have to take it apart fully?
You should still take it apart anyway. Even if you dont think water would have gotten somewhere. Wate has a way of getting into everything. All the little nooks an crannys that you may not be able to see. There's also a chance of water sitting on the underside of the motherboard. I highly advise you disassemble the entire rig and dry the whole thing piece by piece for 24hours. Even if a part seems dry, dry it anyway.
It needs to be dry inside and out.
Also Please remove your cmos battery. This is suppling a small current to the bios chip. If this shorts out from the water, It could damage the bios severely.
Ok... I will take it apart. Do you think I should also take apart the gpu? I'd rather not but I will if necessary. Also the cpu cooler?
Quote
even the gpu and the cpu cooler?
