Would it be safe to say that this board could handle 64GB of 3000MHz memory while populating all eight slots? Why would the timings of one set of four sticks be okay, but eight sticks not be? I guess I don’t really understand the concept of memory timings.
Main System-
Case: Lian Li PC-O11 Dynamic PCMR Limited Edition
Motherboard: Asus X570 Crosshair VIII Hero WiFi
CPU: AMD Ryzen 9 3950X
GPU: Asus GeForce RTX 2080Ti Strix OC
RAM: 4x16GB (64GB) G.Skill Trident Z Neo DDR4 @ 3600MHz/C16
Storage: 1x Samsung 970 Evo 1TB NVMe M.2 SSD (OS), 4x Samsung 860 Evo 2TB SATA SSD
PSU: EVGA Supernova G3 1000
Cooling: Custom Loop, EKWB Quantum Velocity Copper/Plexi w/ D-RGB Upgrade Kit and Black Frame, EKWB Quantum Vector Strix Nickel/Acetal D-RGB w/ EKWB Strix Backplate in Black, Watercool MO-RA3 420 LT (180-200mm Fan Mount, Classic Black Grill High Version, Wall Mounting Bracket, Heatkiller Tube Mounting Bracket, PCIe Slot Terminal Adapter), Heatkiller Tube 200 w/ EKWB D5 PWM Pump, Bitspower Fittings, 6x EKWB Vardar X3M D-RGB 120mm Fans, 4x Noctua NF-A20 Chromax 200mm Fans, EKWB ZMT Tubing, EKWB HD-PETG Tubing
ITX System-
Case: NCase M1 V6.1
Motherboard: Asus X570 ROG Crosshair VIII Impact
CPU: AMD Ryzen 9 3900X
GPU: NVIDIA GeForce RTX 2080Ti Founders Edition
RAM: 2x16GB (32GB) G.Skill Trident Z Neo @ 3600MHz/C16
Storage: 1x Samsung 970 Evo Plus 500GB NVMe m.2 SSD (OS), 1x Samsung 860 Evo 2TB m.2 SSD (Storage)
PSU: EVGA Supernova 650 GM (SFX)
Cooling: Custom Loop, Watercool Heatkiller IV Pro Black Copper (AM4), Watercool Heatkiller IV RTX 2080Ti Acetal Nickel w/ Black Backplate, 2x XSPC TX240 Radiators, Iceman Cooling Ice P5 Pump/Reservoir Combo, Bitspower Fittings, EKWB ZMT Tubing
https://linustechtips.com/topic/851239-asus-rog-zenith-extreme-memory-question/
it will work fine.
timings aren't the issue, frequency is (3000Mhz).
the memory controller has a slightly harder time handing all 8 sticks compared to just 4, but the difference is negligible, especially with relatively normal-speed 3000Mhz RAM. if you were going for 3600Mhz, then it might matter, but for 3000Mhz, you should be able to get it stable on all 8 sticks with minimal effort (5-30 mins)
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
7 minutes ago, RadiatingLight said:
it will work fine.
If I bumped that to 3200MHz would I fare the same? That’s what’s in my system right now.
Main System-
ITX System-
Case: NCase M1 V6.1
yeah, mostly the same, although it would take more tweaking to get the system stable.
maybe 15-60 mins of tweaking, depending on how exact you want to go
(if you just bump up SOC voltage and RAM voltage a bit, then it should be easier to get 3200)
Laptop:
The 200MHz difference probably wouldn’t change the performance that much. I’ve never screwed with voltages or anything. Most of my memory overclocking experience comes from XMP.
Main System-
ITX System-
Case: NCase M1 V6.1
XMP 3000Mhz or above is unlikely to work first-try on Ryzen. you'll have to tweak it a bit
(link in sig for a memory overclocking guide if you want)
Laptop:
with that many sticks u gonna need to overvolt ur mem controller for stability probably btw
Gotcha. I’ll take a peek at it and see what I can do. Thanks for the responses guys!
Main System-
ITX System-
Case: NCase M1 V6.1
