So I'm in the process of deciding a build as my current PC is nearly 5 years old and has and I3 2100. I have already got a 1TB HDD and a GTX 1050Ti for the build but am unsure with the rest. My budget is around $1000/£800 for the rest of the build, and below is the current build specs I have come up with and their amazon links respectively:
Aerocool Aero-500: https://www.amazon.co.uk/Aerocool-Aero-500-Gaming-Window-Reader/dp/B015B3ROCC/ref=sr_1_28?s=computers&ie=UTF8&qid=1508696328&sr=1-28&keywords=atx%2Bpc%2Bcase&th=1
EVGA 600 W1, 80+ WHITE 600W: https://www.amazon.co.uk/EVGA-WHITE-Warranty-Supply-100-W1-0500-K3/dp/B01127D0MY/ref=zg_bs_430514031_20?_encoding=UTF8&refRID=77NPAVYMNFW586DX8EQC&th=1
ASUS STRIX B250F: https://www.amazon.co.uk/ASUS-STRIX-B250F-GAMING-Motherboard/dp/B01MRZXINR/ref=sr_1_4?s=computers&ie=UTF8&qid=1508014819&sr=1-4&keywords=LGA+1151
Intel Core i5-7500: https://www.amazon.co.uk/Intel-i5-7500-Frequency-Cache-Processor/dp/B01MZZJ1P0/ref=sr_1_1?s=computers&ie=UTF8&qid=1507926431&sr=1-1&refinements=p_89%3AIntel%2Cp_n_condition-type%3A12319067031%2Cp_n_feature_two_browse-bin%3A12724455031
HyperX FURY DDR4 16GB 2400MHz: https://www.amazon.co.uk/HyperX-FURY-DDR4-HX424C15FB2K2-16/dp/B01D8U2B8W/ref=sr_1_7?s=computers&ie=UTF8&qid=1508055131&sr=1-7&keywords=HYPERX+16GB
DREVO X1 Series 240GB SSD: https://www.amazon.co.uk/gp/product/B01GPEA1QC/ref=s9_acsd_top_hd_bw_bT8M1X_c_x_3_w?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=merchandised-search-3&pf_rd_r=63GJN7DE5GPP9DKMJKXQ&pf_rd_t=101&pf_rd_p=aa0c322d-0ded-5ff7-80a3-16bcdcc03ced&pf_rd_i=430505031
NZXT RL KRX52 5/240 mm: https://www.amazon.co.uk/gp/product/B06XYSVXYX/ref=s9_acsd_zwish_hd_bw_bT8KSl_c_x_w?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=merchandised-search-6&pf_rd_r=XV66SQ6QYCN92PJHV7G9&pf_rd_t=101&pf_rd_p=cdfe7b69-8f39-5168-9e52-1c6fe2791197&pf_rd_i=430499031&th=1
Gigabyte Nvidia GTX 1050Ti WF2 OC 4GB: https://www.amazon.co.uk/Gigabyte-Nvidia-1050Ti-GDDR5-PCI/dp/B01MG15JZS/ref=sr_1_1?s=computers&ie=UTF8&qid=1508761275&sr=1-1&keywords=1050+ti (Already have)
Seagate 1 TB Hard Drive: https://www.amazon.co.uk/Seagate-Barracuda-7200-Desktop-Hard-Drive/dp/B01LNJBA2I/ref=sr_1_4?s=computers&ie=UTF8&qid=1508761299&sr=1-4&keywords=1tb+hdd (Already have)
Would be great to get some feedback on it and any changes i should make.
Thanks!
https://linustechtips.com/topic/850902-build-help/
Does the budget include peipherals?
My personal PC:
CPU: Intel - Core i5 8600k  Cooler: CoolerMaster Hyper 212 Evo  Motherboard: Asus Prime Z370-P RAM: Corsair Vengeance LPX 2x8GB 3000MHz DDR4 Storage: San Disk SSD Plus 240 GB + WD Caviar Blue 1TB  Video Card: Gigabyte GTX 1070 Windforce OC 8GB Case: Phanteks Eclipse P400S Tempered Glass ATX  PSU: Corsair CX550M 80+ Bronze Certified Semi Modular PSU.
Peripherals:
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse Keyboard: Rii - RK100 Wired Standard Keyboard Monitor: Asus - VG248QE 24.0" 1920x1080 144Hz Monitor Headset: Logitech - G430 7.1 Channel Headset Speakers: Logitech - Z150 0W 2ch Speakers
Laptop:
Medion  E6239 MD99452
PCPartpicker Link:
https://uk.pcpartpicker.com/list/VVwvHN
https://linustechtips.com/topic/850902-build-help/#findComment-10604851
There is no reason at all to get a locked Kaby Lake I5. I would change it to this. If the budget doesn't include the GPU, you could go for something like the 8400. What will you do with the PC?
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (£170.34 @ Aria PC)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  (£74.30 @ Amazon UK)
Memory: Patriot - Viper 4 16GB (2 x 8GB) DDR4-3000 Memory  (£144.78 @ Ebuyer)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  (£77.93 @ Ebuyer)
Storage: *Seagate - Constellation ES 1TB 3.5" 7200RPM Internal Hard Drive  (£33.19 @ Aria PC)
Case: Phanteks - Eclipse P300 Tempered Glass ATX Mid Tower Case  (£51.95 @ Aria PC)
Power Supply: Corsair - RMx 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£74.99 @ Corsair UK)
Total: £627.48
Generated by PCPartPicker 2017-10-25 10:43 BST+0100
https://linustechtips.com/topic/850902-build-help/#findComment-10604853
Hi there VexD :)
I bought my PC 6 months ago doing a very deep research on the web about every single part of it.
So you can look it up in my profile and then changing the box, the cpu and the graphic card to lower the price.
I would recommend to sport a good 1060 in that budget (since a 1070 would go out of range or you would need to take it out from the rest of the peripherals) and a good i5 - K with possibilities to overclock (K means that you can overclock it)
And if you want a personal opinion about the graphic card. I would just wait and save a couple of months, add some money to the budget and take a 1070. Is hands down the best card price/quality on the market right now (and for such you could also wait to the 1070ti releasing so they will down the price on the normal 1070)
https://linustechtips.com/topic/850902-build-help/#findComment-10604854
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  (£181.98 @ Ebuyer)
Motherboard: ASRock - Z370 Pro4 ATX LGA1151 Motherboard  (£107.08 @ Eclipse Computers)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive  (£77.95 @ Amazon UK)
Case: Deepcool - DUKASE ATX Mid Tower Case  (£35.94 @ Ebuyer)
Power Supply: EVGA - SuperNOVA G3 (EU) 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£76.96 @ Aria PC)
Total: £624.69
Generated by PCPartPicker 2017-10-25 10:51 BST+0100
https://linustechtips.com/topic/850902-build-help/#findComment-10604873
