So I haven’t built a computer in going on about 16 years since my sophomore year in high school, and now it’s time to upgrade from my still very reliable but definitely dated Inspiron 660. I’ve decided to build my next system rather than get another pre built.  Below is what I think I’ve settled on, but I’d like to get some thoughts on the parts I’ve selected, and see if maybe there is something I missed or may work better. Budget is sub $1100(USD)
Will be doing some moderate gaming, definite video streaming, and I have 3 monitors.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor
Motherboard: MSI - B350M MORTAR ARCTIC Micro ATX AM4 Motherboard
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory
Storage: Kingston - A400 120GB 2.5" Solid State Drive
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card
Case: Phanteks - ECLIPSE P400 ATX Mid Tower Case
Power Supply: SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply
Total: $1087.74
https://linustechtips.com/topic/850539-parts-for-build/
Have a look at this list
https://pcpartpicker.com/list/stR8f8
My personal PC:
CPU: Intel - Core i5 8600k  Cooler: CoolerMaster Hyper 212 Evo  Motherboard: Asus Prime Z370-P RAM: Corsair Vengeance LPX 2x8GB 3000MHz DDR4 Storage: San Disk SSD Plus 240 GB + WD Caviar Blue 1TB  Video Card: Gigabyte GTX 1070 Windforce OC 8GB Case: Phanteks Eclipse P400S Tempered Glass ATX  PSU: Corsair CX550M 80+ Bronze Certified Semi Modular PSU.
Peripherals:
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse Keyboard: Rii - RK100 Wired Standard Keyboard Monitor: Asus - VG248QE 24.0" 1920x1080 144Hz Monitor Headset: Logitech - G430 7.1 Channel Headset Speakers: Logitech - Z150 0W 2ch Speakers
Laptop:
Medion  E6239 MD99452
PCPartpicker Link:
https://uk.pcpartpicker.com/list/VVwvHN
https://linustechtips.com/topic/850539-parts-for-build/#findComment-10600781
11 minutes ago, seon123 said:
What will you do with the PC? The motherboard is not very good, and the PSU is old and very mediocre. Try to get a larger SSD, around 250GB. The TG version of hte case shouldn't cost much more than the non TG version, if you want that
Can you expound on why the motherboard isn’t very good? Also, I only plan to store then OS in the SSD, so to me (possibly ignorantly so) it seems the rest of the space would go to waste. Is there a benefit to having more space on the SSD?
https://linustechtips.com/topic/850539-parts-for-build/#findComment-10600782
You could store your most played games on the SSD allowing for faster load times. The SSD will not improve in game preformance so unless you plan on using software such as Photoshop etc. a larger SSD will not be needed.
My personal PC:
Peripherals:
Laptop:
PCPartpicker Link:
https://linustechtips.com/topic/850539-parts-for-build/#findComment-10600791
That looks pretty good. Are there any significant advantages of that system over the one I posted?
(Not trying to be contrary or argumentative just trying to be more informed)
https://linustechtips.com/topic/850539-parts-for-build/#findComment-10600798
The VRMs and VRm heatsinks are pretty bad. It should be fine, as long as you don't get a watercooler or high end air cooler. You can easily fit more than just hte OS on a 120GB SSD. A few games, but it'll feel a little small. Higher capacity SSDs are technically faster, but it's not noticable.
https://linustechtips.com/topic/850539-parts-for-build/#findComment-10600801
