Hi,
I recently woke up in the morning to turn on my pc but It failed to post even though it was working perfectly fine the night before. It seems like the motherboard is no longer detecting the graphics card which is strange, as I tested the gpu in a friends system in it worked no problem. I also tried putting the gpu out of my friend's system into mine and it worked fine but if I put my gpu in I get no display output just a black screen What the hell is going on the system ran perfectly fine in its original config for more than 2 months why has it stopped working now.
Specs:
cpu r3 1200
mobo asrock b350 pro 4
memory corsair vengance 2x4gb 2400mhz ddr4
psu silverstone strider plus 500w 80plus bronze
storage crucial mx100 512gb ssd
case cm 690 iii
Quote or tag me @Lemtea so I can see your reply.
DAYBREAK: R5 5700X3D | RX 9070XT | 32GB RAM | 1TB 970 EVO PLUSCRUCIAL MX200 1TB SSD | 4TB HDD | CORSAIR TX650M | PURE BASE 500DX | WIN 10
LAPTOP: DELL XPS 15 9570 i7 8750H | GTX 1050TI MAX Q | 16GB RAM | 500GB PCIE SSD | 4K TOUCHSCREEN Win 10 PRO
https://linustechtips.com/topic/850474-strange-gpu-issues/
30 minutes ago, The Wanted said:
Hi,
Specs:
cpu r3 1200
memory corsair vengance 2x4gb 24oomhz ddr4
case cm 690 iii
Try putting your GPU in a different PCI-E slot, even not x16.
Run a memtest on the system with both sticks in slot. If it pass, good. If it doesn't, take one stick out and test the other, then switch sticks and test again.. and so on
https://linustechtips.com/topic/850474-strange-gpu-issues/#findComment-10600171
grab your friends GPU, run DDU to remove the drivers and see if that dose anything for you. also try a BIOS update and a CMOS reset. JayzTwoCent had a similar problem with a pair of Titan cards recently
Builds:
https://linustechtips.com/topic/850474-strange-gpu-issues/#findComment-10600188
Still get no display output with a different pcie slot and memory reseated with one dimm removed
https://linustechtips.com/topic/850474-strange-gpu-issues/#findComment-10600247
bios was already the latest version and I tried using DDU but still have the same issue
https://linustechtips.com/topic/850474-strange-gpu-issues/#findComment-10600251
try going back a version on the BIOS and see if that helps
Builds:
https://linustechtips.com/topic/850474-strange-gpu-issues/#findComment-10600374
I've had this issue before.
This could be due to the contacts on the GPU becoming damaged and not being read by your motherboard. As you can understand, I'm sure, each motherboard is created and designed differently including the use of PCI-E Slots. It could just be that your friends PCI-E connectors sit slightly higher up than yours allowing the contacts to meet despite any damage.
Can I recommend this to you?
https://www.ebay.co.uk/i/132285389650?chn=ps&dispItem=1&adgroupid=52097426788&rlsatarget=pla-382293664527&abcId=1058846&adtype=pla&merchantid=101457949&poi=&googleloc=9044987&device=c&campaignid=863276125&crdt=0
B| Obligatory Signature Text B|
https://linustechtips.com/topic/850474-strange-gpu-issues/#findComment-10600554
