22 hours ago, PCGal said:
Hi everyone, I'm trying to find the smallest m-ATX case I can. Price is not a concern, but it has to support a GTX 660 Windforce by Gigabyte, and a normal desktop ATX PSU. Thanks in advanced.
Couple of options to consider
https://pcpartpicker.com/product/tH2rxr/lian-li-pc-m25b-microatx-mini-tower-case-pc-m25b
https://www.amazon.com/dp/B00WJOXW96/ref=twister_B016BCLDO2?_encoding=UTF8&th=1
https://www.newegg.com/Product/Product.aspx?Item=9SIA66Z3TV7273 (comes in a few different colors)
Also found this, which looks like a DAn style case in mATX form factor (not out yet, but soon tm)
https://kimeraindustries.com/cerberus/#cerberus-hero
https://linustechtips.com/topic/849756-smallest-micro-atx-case/#findComment-10596663
11 hours ago, TVwazhere said:
First two options, crazy prices!
https://linustechtips.com/topic/849756-smallest-micro-atx-case/#findComment-10599448
It's easy and inexpensive to build bigger cases :/ (since it's easier to plan out) Theyre honestly not that terrible in terms of case prices though
https://linustechtips.com/topic/849756-smallest-micro-atx-case/#findComment-10600803
3 minutes ago, PCGal said:
I need the portability, and I'm not a fan of bigger cases.
Hence the reasons I recommended what i did!
https://linustechtips.com/topic/849756-smallest-micro-atx-case/#findComment-10605355
