It looks like some of the sectors are failing, I'd keep an eye out for anymore errors.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
My guess is that the hard drive has got a dead sector (which happens all the time and why they all come with spare sectors) but there's no spare sector left to relocate data to. This means the more sectors die, the actual capacity of the drive will be reduced.
Desktop benching:
Uncorrectable error is just what it says, at some point previously there was some data it couldn't read. I might not be exactly correct on pending sector, but the drive has detected an area with a problem, and it can remap it on the next write to the affected area.
The drives are supposed to work around growing errors, but to me this is a sign of a disk that is starting to go. Download the WD diagnostic tool, and run a read only scan on it and see what it says. If you have any data of importance on it, I'd look to backup elsewhere as a precaution.
The drive is on it's way out.
You can download the WD hard drive software that will scan and attempt to repair the sectors.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
Fortunately I always back up every file on an external hard drive. Though I am currently running WD diagnostic tool, would CHKDSK scan be beneficial in this case?
I've not used CHKDSK in a while so I'm not sure what the available options are these days. A surface scan will be no better than the WD tool. It might also pick up filesystem errors but that's a separate problem, unless there is data loss from the drive it might help restore around that.
Sorry for the late reply, I did a scan with WD tool and it took almost 7 hrs to complete. At last when I clicked on Repair, some kind of error popped out and the repair failed. Now what should I do? Do a rescan again, I guess?
If it is still under warranty you might start looking at that.
I read somewhere that even if WD provides a 3 year Warranty, what they mean by that is 2400 hrs/year which equals to 7200 hrs. And the drive is already over that mark. Is this case true?
You'd have to ask WD, not me. Try their web site. I haven't heard of that before as a limitation.
So my drive failed the WD extended test, though it passed the quick test. So i guess I can still cover some miles out of it?
You might can get some more life out of it, but I wouldn’t risk it with data you need. It’d be fine as a scratch disk with some non-important data, but not much more.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
Be careful, I had a WD 1TB OEM one from way back when and it had the same issue then totally fucked my OS bootup for some reason, had to disable it via Devmgmt for it to stop fiddling with my SSD boot, i'd look at backing important stuff up asap if i were you.
Regular human bartender...Jackie Daytona.
