It should be auto. However, when you upgrade in the far future, I wouldn't get another SSHD, I personally think they are terrible, and seem to fail a bit more often, and when they fail, you lose everything on both the SSD and HDD.
But, I think the caching is all handled internally by the drives open logic.
The drive uses it by itself, no driver needed. For more clarification of how the FireCuda drives work, ask @seagate_surfer
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
Yeah as said. The drive will pick what to use the 8gb on. However, I have heard there is some crazy coding that would allow you to control it if you really wanted to. Not sure it would be worth it, but it does exsist.
 Current System: MoonLightRyzen
CPU: Ryzen 7 1700x @ 3.9ghz  Board: Asus ROG C6H  Ram: G.Skill TridentZ 32gb 3000mhz  Case: Lian Li PC-O11 Dynamic
GPU: Asus ROG Strix GTX 1070 OC in SLI M.2: Samsung 960 Evo 250gb SSD: Samsung 850 Pro 512gb x2 HDD: Seagate Barracuda 3TB and 2TB
PSU: Corsair RM850x White  Cooler: XSPC/Phanteks Custom Loop
Backup System: RedDragonV3.0
FX-8350 @ 4.7ghz, Asus TUF Sabertooth 990fx r3.0, MSI GTX 1060 6gb Gaming X, Crucial Balistix Tracer 32gb, M.2 Samsung 960 Evo 250,
Seagate Firecudda 2tb, Seagate Barracuda 2tb, NZXT S340 Elite White, Kraken X62, Corsair RM750x, Hue+
Thanks for the call-out here.
4 hours ago, dafo446 said:
my tummy hurt so got to go no time for research i just copied and install new sshd do it need a driver to use that 8gb of cache? or just auto op thank!
As others have mentioned, you don't need to install anything additional. Basically the way the SSD cache on the FireCuda works is that, as you use the system with the drive in it, it automatically starts to look at what you're accessing most frequently, and prioritizes that data for the SSD cache, then puts everything else on the spinning capacity. You don't need to do anything as this process is all automated, ideally it will put OS files on there for faster boot times, and if you're trying to get load-time benefit in any kind of gaming experience, the best bet is to play one game over a course of time so some of that data makes it onto the SSD cache as well, versus playing multiple different games in the same time frame.
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
No problem. I have used a FireCuda (I have one in my laptop, and I really like it) and I thought that was how it worked, but I knew you'd know more.
Main System: Phobos
