Budget 80+ Power Supply
Go to solution Solved by Jurrunio,
19 minutes ago, ezio16 said:
Thanks for the suggestions.
Currently using 400 W PSU only, but may upgrade the system after a while. So just to be safer, thought to go around 500 or 550 W.
Corsair TXM series is any better than CXM ?
I dont see much upgradability for this system (unless dumping both the CPU, GPU and mobo isnt considered a completely new system).
Corsair CXM<CSM<TXM<RMx. TXM is much better than CXM (even the old ones are good).
Hi,
I'm in need of a 80 Plus Semi Modular/Modular Power Supply around 500 W for my old system.
My PC Specs are as below.
ASUS M2N68 AM+ Motherboard
AMD Athlon II 5000+ Dual Core Processor
4 GB DDR2 RAM
Samsung 850 EVO 250 GB SSD
Seagate Barracuda 3 TB HDD 7200 rpm
Nvidia Geforce n210 1 GB GPU
LG DVD-R/W 24x internal
LG 32MN58H FHD Monitor
Please suggest me a best Semi Modular PSU for this spec with good warranty.
PSU Brands available in my country are Corsair, Antec, Seasonic and Cooler Master.
Budget is around $60 to $80 USD.
Rig 1: Corsair Carbide Spec Alpha Mid-Tower Case, Corsair RM750x PSU, Intel Core i7-6700, Gigabyte GA-Z170N-WIFI-Rev 1.0 MB, HyperX DDR4 8 GB 2133 MHz, Kingston 240 GB SSD, WD Blue 2 TB, Samsung 23'' FHD Monitor
https://linustechtips.com/topic/848478-budget-80-power-supply/
nah, even 400w psu can suit your needs.
Corsair CXM and Seasonic M12ii are both good choices. M12ii is based on old tech and somewhat outdated, but it is certainly well-proven.
Desktop benching:
https://linustechtips.com/topic/848478-budget-80-power-supply/#findComment-10578353
https://linustechtips.com/topic/848478-budget-80-power-supply/#findComment-10578362
Desktop benching:
https://linustechtips.com/topic/848478-budget-80-power-supply/#findComment-10578387
Planning to upgrade the Mobo alone to AM3+ as it's a secondary PC.
Okay then, will try to get TX550M.
However can't find it in any online stores. Will have to check locally.
Thanks for your help.
https://linustechtips.com/topic/848478-budget-80-power-supply/#findComment-10578403
Corsair CX-M (grey label) will do the job
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/848478-budget-80-power-supply/#findComment-10578419
I can't seem to find the TX-M or CX-M within my price range as 550W is not available anywhere and only listings start from 650W in available sites.
Please suggest me some other model within my budget.
https://linustechtips.com/topic/848478-budget-80-power-supply/#findComment-10582273
Provide a website/store and I'll see what I can find.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/848478-budget-80-power-supply/#findComment-10582456
These are some sites available here.
https://www.theitdepot.com
https://www.mdcomputers.in/
https://www.primeabgb.com/
http://www.theitwares.com/
Price range is within 4 to 5 thousand max.
Thanks.
https://linustechtips.com/topic/848478-budget-80-power-supply/#findComment-10582755
Thanks.
Not exactly many choices...
Within that price range, the only choice I'd consider as "alright" is the Antec VP550P. It's DC-DC regulated and made by Delta Electronics (I know, I know... don't buy by brand... but you can make an exception here and there).
https://www.theitdepot.com/details-Antec+VP+Series+550W+Power+Supply+(VP550P)_C14P18600.html
https://linustechtips.com/topic/848478-budget-80-power-supply/#findComment-10582793
Within that price range, the only choice I'd consider has "alright" is the Antec VP550P. It's DC-DC regulated and made by Delta Electronics (I know, I know... don't buy by brand... but you can make an exception here and there).
Okay thanks.
I had that in consideration first, but didn't go for it as it's lacking any 80 Plus certification.
Will see and may get the below one.
https://www.theitdepot.com/details-Antec+VP+Series+600W+Power+Supply+(VP600P)_C14P26617.html
Thank you.
https://linustechtips.com/topic/848478-budget-80-power-supply/#findComment-10582798
8 minutes ago, ezio16 said:
Okay thanks.
Thank you.
The VP600P is based on a completely different platform and is made by Fortron/FSP. If I were you, I would not get that unit and just stick with the VP550P.
The fact that it doesn't have 80+ Certification doesn't reflect its quality as a PSU.
https://linustechtips.com/topic/848478-budget-80-power-supply/#findComment-10582810
 Ohh, I thought both had same quality and same manufacturer. So thought to go for the extra 500 W.
So I'll stick with VP550P if I don't find any deals on CX-M or TX-M.
Thanks.
https://linustechtips.com/topic/848478-budget-80-power-supply/#findComment-10582819
Thanks.
Yep. Antec is weird with their naming schemes.
https://linustechtips.com/topic/848478-budget-80-power-supply/#findComment-10582825
