https://linustechtips.com/topic/847205-pc-first-build-help/
better psu, raidmax PSUs tend to be horrible. get a corsair CX instead. also, get a cheaper 1050ti or gtx 1060 3gb instead(6gb if you have money to spare).
https://linustechtips.com/topic/847205-pc-first-build-help/#findComment-10564087
What's your budget? What are you going to do with the system? If you are gaming on it then it makes more sense to go with a ryzen 3 1200 and a better gpu - it's going to be a more balanced build. Ryzen gains performance with faster memory so I would say pick up a faster kit. Also I would pick a better psu - something from corsair or evga.
https://linustechtips.com/topic/847205-pc-first-build-help/#findComment-10564090
With that GPU, his memory speed will hardly be what's gonna be holding his performance back, getting a fast kit of RAM right now is comically overpriced tbh
https://linustechtips.com/topic/847205-pc-first-build-help/#findComment-10564098
21 minutes ago, Hcraft04 said:
Get a cheaper 1050 ti,a strix wont help a lot in gaming than a normal 1050 ti like a Zotac one,means better is to get a cheaper 1060 6 GB and get a Better PSU like a Cosair CX Series PSU,since the one you chose is not a good psu,Ummn ryzen benefits from faster ram,means try to feed it faster ram if u can.
PC Specs:Custom Built PC
CPU:AMD Ryzen 3 1200 GPU:Zotac GeForce GTX 1050 TI Mini RAM:Corsair Vengence 2400 MHz DDR4 Motherboard:ASUS Prime B350M-A AM4 Motherboard Case:Corsair 100R PSU:Corsair VS450
Laptop Specs:Acer TravelMate 8472
CPU:Intel Core i5 560M Memory:2GB DDR3 CPU:Intel HD Graphics Case:Its a Laptop Motherboard:Laptop Motherboard
https://linustechtips.com/topic/847205-pc-first-build-help/#findComment-10564113
2 minutes ago, PhaseShift said:
That's why I suggested a better gpu :)
Yes, but he's better off sticking to R5 if it's isn't just for gaming, perhaps get a 1400 instead but getting an R3 with Fast ram is gonna be a lot slower than an R5 with slow ram. Unless it's only for gaming.
https://linustechtips.com/topic/847205-pc-first-build-help/#findComment-10564122
7 minutes ago, Hcraft04 said:
any better graphics card suggestions and also should I use a ryzen 3 1300x
what's your budget? and just get the 1200 and overclock.
https://linustechtips.com/topic/847205-pc-first-build-help/#findComment-10564614
https://linustechtips.com/topic/847205-pc-first-build-help/#findComment-10564680
