Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/84718-fan-modding/#findComment-1152669
It is possible but I did it with a spare 2 pin fan.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/84718-fan-modding/#findComment-1152673
i dont realy wanna spend money on it :L
usb outputs at 5v so you could technically run it at lower speeds if you splice a usb cable and connect the red/black wires to the fan pins
would 2 usb cables work??
If you tell a big enough lie and tell it frequently enough it will be believed.
-Adolf Hitler
https://linustechtips.com/topic/84718-fan-modding/#findComment-1152689
This was what i was gonna say, I done it a couple months ago when i got bored. I get bored a lot...
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
https://linustechtips.com/topic/84718-fan-modding/#findComment-1152701
yes, just wire it in parallel, but that would be pretty loud. I recommend a single 5v port for low power impact and noise. Oh, and if your laptop is overheating, it is most likely going to be dust build up causing the problem. I've seen laptops run at 95 C with the heatsinks choked with dust.
Build: Fx-8120@4.1ghz,  Gtx770@1.0ghz,  16gb Patriot memory,  Cheap case from thermaltake
https://linustechtips.com/topic/84718-fan-modding/#findComment-1153088
 i need the fan for my 9 usb erupters and noise isnt an issue and my laptop it fine :D
-Adolf Hitler
https://linustechtips.com/topic/84718-fan-modding/#findComment-1155175
