I'm having issues with Cisco AnyConnect. I've set IPSec on my Pfsense box and I'm trying to connect to it. The error I'm getting is "No valid certificates available for authentication"
How do I sort out the certificate?
https://linustechtips.com/topic/846843-cisco-anyconnect-issue/
You need a Cisco AnyConnect capable device. You'll have to install it on an ASA or other Cisco firewall appliance to run it properly, otherwise you'll have to use something like OpenVPN.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/846843-cisco-anyconnect-issue/#findComment-10560122
Damnit. :(
https://linustechtips.com/topic/846843-cisco-anyconnect-issue/#findComment-10560145
How have you done a cisco security class and asked this? No offence intended btw :P long time ago or they didn't cover the basics of anyconnect
I'm going to put a link to my PC specs which actually aren't my PC specs and I cry myself to sleep everyday so I can have these PC specs but I can't afford these PC specs so PC specs PC specs PC specs PC specs PC specs PC specs.
https://linustechtips.com/topic/846843-cisco-anyconnect-issue/#findComment-10560935
