Help with ethernet limited speed
Ardy
So last week my ethernet port died and in the meanwhile i had to use one of those usb wifi sticks. After a few days my pcie ethernet card arrived and it's working perfectly fine. The only problem is that now my ethernet connection shows up the ssid name of the wifi and it's somehow limiting my speed to 450mbps. And for some reason my ethernet port on the mobo came back to life and it's working again, so i tested that too and i'm still limited to 450mbps. Before connecting my pc via wifi i didn't have this problem and i could reach 1gbps without a problem, downloading up to 85MBps. Do you guys know how can i solve this problem? And why is that after using wifi once now my ethernet is limited to the 2.4ghz wifi speed?
Is your Wifi adapter still connected? Sounds like it.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
Windows is supposed to prefer Wired over Wireless but it's possible that something got messed up and it now prefers wireless for some reason.
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
Go into your network and sharing center, on the left menu choose {change adaptor settings}... then right click the wifi adaptor, and then from the context menu choose {disable}
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
My adapter is no longer connected to the pc, i'm using only the wired connection.
what is your setup?
Do you by any chance have a access point and routers which both have DHCP running?
Try turning off all network infrastructure devices (modems, routers, AP's etc) and leave the off for a minute or so (if you have dhcp servers on multiple device make sure you remove all leases too). The boot them up again in order in which they appear in the line (so first the modem, then your core router etc). now boot up the computer and see if that makes any difference.
