Hi guys, so I was away for a couple weeks and came back to find that I could't power on my pc. Every time i press the power button, the lights come on and the fans start spinning for 2 seconds before turning off and restarting to do the same thing in a loop. I've tried everything from the read me post including the paper clip test which the psu passed, resetting cmos, booting without gpu/ram/hdd, outside the case. The motherboard does't beep and the cpu fan doesn't run, only a red led lights up. So any ideas or do i have a dead mobo on my hands??
My specs are
i5 4440
Asus B85 pro gamer
kingston hyperx 4gb x2
corsair cs650m
Sapphire r9 280x vapour x
1TB WD
windows 10 64bit
https://linustechtips.com/topic/846412-pc-wont-post/
Suggest a teardown and building everything from scratch
Mobo: ASRock B150M Pro4s | CPU: Intel core i7 7700 with stock cooler | Storages: 2x80GB Seagate Barracuda 7200rpm + Zotac 120GB | Memory: 2x4GB Kingston HyperX Fury | PSU: 400W HYN 80+ | GPU: PowerColor Radeon R9 270X 2GB | Tower: an old one from the other decade | Monitor: ASUS Widescreen 900p + ViewSonic FHD| Speaker: microlab
https://linustechtips.com/topic/846412-pc-wont-post/#findComment-10556096
