OLD/NEW RIG, GTX 1080TI, THERMALTAKE P5 CASE
chefjrf
update to my pc
see my other post for info on my old rig
got rid of the 290x crossfire cards and went for a single gtx 1080ti
went for a thermal take p5 case and hardline tubing
next step is to put the gpu into the loop, wasn't going to do this originally as i liked the look of the cards and wasn't that bothered about overclocking so the temps weren't too bad but after installing it, i think it clashes, will post more pics when this is done
You have to put GPU in water loop as well.
It will look even better because you will be able to see water flow in GPU block.
And it will bring down your GPU temps by a lot, even if you are not looking for that.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
agreed
just ordered the block
going in next week
