So I was really excited to see the CM h500p as since it had been shown at computex I knew I wanted that to be my next case as it would look great and had plenty of room for a custom loop. After seeing all the more negative reviews for it though I'm at a loss as to what case I want to go with instead or just use the h500p anyways. This will be my first custom loop as all I have worked with before are AIO's so something that is a little easier to work in would be great! I am looking to cool my CPU and VRM with a mono block as well as my 1080ti so I was thinking about having 1x 360/420 rad as well as 1x 240/280 rad. Just need some other people to bounce some ideas off of. Thank you in advance!
Current Build:
CPU: I7-6700k
MoBo: Asus Maximus IX Hero
GPU: Asus Strix 1080ti OC
RAM: 2x 8GB (3000) Trident Z RGB
Storage: 1x 2.5" SSD; 2x 3.5" HDD
Case: NZXT Noctis 450
https://linustechtips.com/topic/845295-case-suggestions-for-custom-loop/
I'd go for a Corsair Crystal 460X or 570X for a custom loop
Define C series (TG, Meshify, Vanilla) are all nice compact challenging cases. Bigger cases are obviously generally easier to work in, so kind of depeds on what you want.
Quote
"(1) High Frame Rates (2) Ultra Graphics Settings (3) Cheap>>>>Choose only two" Chevaishr
https://myanimelist.net/profile/AnalCavity
PCPartPicker URL
https://pcpartpicker.com/b/bsJ8TW
I love the look of the Meshify C it just doesn't look like it has a ton of room to work in which for my first attempt at a loop might be difficult, and the 570x is perfect in size and looks but my lord that's a lot of tempered glass. However I feel like I am leaning towards the 570x just purely because of it's size and looks as it even has a place for easy pump/res mounting at the end of the psu shroud.
