Max thickness for custom mobo stand-offs?
Solved by Mortis Angelus,
49 minutes ago, W-L said:There is no max height per say as long as the standoff is properly secured and the board can be fastened to it.
I realize I used wrong wording. Thickness = diameter.
But I found my answer in this thread over on tomshardware:
http://www.tomshardware.co.uk/answers/id-2449956/motherboard-standoff-dimensions.html
"...the standoff provided has to be a minimum of 6.5mm and the external cross section has to fit within a 10mm x 10mm area around the standoff hole."
That was the answer I was looking for.
