Hello, can you use a powered usb hub to power RPI's or other SBC's.
Is there any easy way to power multiple SBC's easily because im a bit limited on plugs ( also im not a confident soldered so no soldering onto gpio pins etc)
Would any of these work?
Much thanks,
Scrub
https://linustechtips.com/topic/844896-powered-usb-hub-for-sbcs/
Yeah those hubs should work, just be sure to get ones with a reputable brand name.
Otherwise the power supply will be garbage
