Mechenical Hard drive recommendation to pair with at 60GB ssd
Solved by N7_Zer0,
Drives don't need to spin-up when you're accessing it unless it spun-down (power saving mode?). You didn't mention which OS you're using but in Win7/8 there is an option to turn off HDD after a certain idle time. Change the time to "never".
9
7
Gurky ·
Posted in Operating Systems4 -
5
joshfrog ·
Posted in Laptops and Pre-Built Systems3 -
4
DASADAS ·
Posted in Troubleshooting4 -
8
