System Partition Extending
Solved by kirashi,
18 minutes ago, Mutahar Farooq said:It's not an OS partition, it's just a partition to store games.
You should be able to extend it just fine, but ALWAYS backup your data whenever using hard drives for any reason whatsoever. This means have a backup even if you're just looking at the drive from across the room as it sits on your dresser or bookshelf, because that drive is considered as good as dead once it's left the factory.
