Hello, i'm looking forward to upgrading my pc to handle games like PUBG, Rust, GTA V, etc. My budget is ~ 300 €, is it worth or should i save some more? Thanks.
PC Specs:
Motherboard: Gigabyte H61M-S2-B3
CPU: Intel Core i5-2400 @ 3.1Ghz
Memory: 1xDDR3 4GB
Graphics card: NVIDIA GeForce GTX 550 Ti
PSU: CODEGEN 500X (500w)
https://linustechtips.com/topic/844189-upgrade-advice/
PC Specs:
Memory: 1xDDR3 4GB
I would upgrade that ram or if you really want to get a new card.
https://linustechtips.com/topic/844189-upgrade-advice/#findComment-10532439
PC Specs:
Memory: 1xDDR3 4GB
slap in another dimm of RAM. 8GB is basically required to run any new game. I would then go and get a 1050 ti for around $150, and use the remaining money to buy a i7 2600k
https://linustechtips.com/topic/844189-upgrade-advice/#findComment-10532443
